Two (or three) questions regarding how to make certain tube frame joints:
1. What do you call those joints often seen on formula cars that are like short tubes with a washer welded on one end?
1b. Are they available for purchase from anywhere?
2. What are the steps to create a bolt hole in a square tube that will not crush when tightened. I think it involves inserting tubing, but I'm not sure how it becomes a flush surface. Maybe it's as simple as grinding the weld flat after the tube is inserted and welded in place?
Thanks. I'll elaborate if the questions don't make sense.
