Results 1 to 2 of 2
    Sacramento, California
    Liked: 97
    Default Super vee throttle shafts
    Question for the collective. My Anson has an intake similar to this one. I am unable to get a low enough idle even with the butterflies fully closed due to an air leak. Spraying carb clean on the throttle shafts and it will practically die. I assume the shafts are leaking. I have yet to take mine apart. Before doing so does anyone know if the shafts have seals or orings that can be replaced? If not I guess I'm looking at rebushing the shafts?
    third stone from the sun
    Liked: 101
    you will want to re bush the shafts
    Dee
    Penske RT 5 287
