Results 1 to 10 of 10
    Senior Member Alex Zeller's Avatar
    Ottawa, Ontario, Canada
    Liked: 43
    Default Front Mounted Oil Pump Plumbing
    Hi Folks,
    I'm finally getting around to plumbing my Mallock (ex - Ray Mallock F3/ and My dad's FB) with the hopes of getting it on track this year. Engine is a brand new 1600 cc Ford Crossflow on new Lotus T/C block, Lotus T/C stroke steel crank, 83.5 CP pistons, etc.
    I would appreciate a quick review of my plumbing assumptions for a new front mounted oil pump installation. See image below.
    Do I have the ports on the pump correct?
Name:	OIl Pump Plumbing.jpg
    1972 Mallock MK12 F3 (ex-Ray Mallock / Alf Zeller)
    https://www.facebook.com/ZellerRacing
    Senior Member racersonly's Avatar
    Oshkosh,WI
    Liked: 95
    Yeah, I’m thinking that you want to have your oil filter between the pump and the engine inlet. You want to filter out any particles before it enters the engine rather than after.
    Jack Bartelt
    Lola T540 CFF
    Destin FL
    Liked: 645
    Alex:
    Consider the engine as the sole source of metal debris and contaminants. And those contaminants and debris accumulate at the lowest point, the dry sump pan.
    The last thing you want is to introduce unfiltered oil into your pump, to SAVE it as well.
    V/r
    Default these guys may have had it figured out
    the oil system
Name:	cosworth oil system.jpg
    Sydney, Australia
    Liked: 146
    Do you yourself a favour, and delete the oil cooler. Not needed with current quality oils. You want the oil hot not cold.
  10. #6
    Destin FL
    Liked: 645
    As most run synthetic oils. IIRC, the viscosity remains fairly uniform.
    Quote Originally Posted by Hawke View Post
    V/r
  11. #7
    Liked: 43
    Thanks for the feedback. I will be watching oil temps during initial testing and can make that decision as needed. I curtainly do not disagree with your premise.
  12. #8
    Liked: 43
    Default Pump
    the oil system
    Thanks for that!
    I actualy forgot that I have that same sketch that Jack Field sent to my dad in 71 in an old file folder. He also sent along some lovely BDD blueprints that I keep thinking I should frame and hang in my home office... It's probably as close as I'll get to a BDA/BDD...
    I will add an in-line filter/screen existing the tank as suggested.
    The Cosworth pump ports in that figure are different to the Titan front mount - Can any one confirm my port assumptions for the Titan pump?
    Cheers, Alex
  14. #9
    Does your oil pan not have a screen in it now? What oil pan?
  15. #10
    Liked: 43
    Yes, It does have a screen. It's a VD pan.
