Results 1 to 10 of 10
    Greer, SC
    Liked: 21
    Default FC 95 Van Diemen and Toy Hauler
    1995 Van Dieman FC
    Race ready and set-up.
    Last run July 23 2023,
    AIM M3Log/Visor XGLog
    3 sets wheels
    Many gear sets
    Diffusers
    Aerocraft541-301-5135
    Van Diemen
    Original
    log books
    New ATL fuel cell 2021
    New Fire Bottle 2021
    New Battery 2022
    FIA rain light
    Original wing
    3 way adjustable Penske Shocks
    Second Pinto engine refreshed 0 time
    Reliable car
    Needs new belts
    MK Rear Quick Lift
    Universal Quick Lift
    Spare Body Parts
    2 Left Side pods
    1 Right Side pod
    Shock cover
    2 radiators
    A arms
    Right rear lower
    Left front lower
    Asking $17,000.00
    Toy hauler trailer is available.
    Located:
    Greer, SC 29651
  2. The following 6 users liked this post:
    Senior Member Agitator's Avatar
    Saluda, NC
    Liked: 144
    I know it's probably been discussed ad nauseam, but what is the typical max height/weight driver the FC95 can tolerate? At 6'2" 205lbs, do I have any chance of fitting in this thing?
    James
    Greer, SC
    Liked: 21
    Quote Originally Posted by Agitator View Post
    James
    Come and sit in the car and find out. Shoe size is more an issue. Size 12 and above is an issue.
    Ft. Myers, Florida
    Liked: 225
    Default Hans
    If you do decide to sit in the car, take your helmet and HANS. It can be done, but you are pushing the upper limit in this generation of Van Diemen. The problem is the lack of clearance behind you to accommodate a HANS. I’m 6-4 and had to move from a 94/95 to a later model for that reason. You may need to move yourself forward, and that creates its own set of issues.
    Atlanta GA
    James
    You will be fine, but you may have to have a foam seat made.
    I used to own this car(I’m pretty sure it was mine, anyway) and I’m 6’2” and 240 ish. I fit without the seat insert that came with it. You are basically sitting on the floor, but that’s no problem. The extra hoop on the roll bar was for added height.
    as Matt said, be concerned with foot room and thigh area through the chassis. The RF95’s are one of the best for bigger people.
    Greer, SC
    Liked: 21
    Default FC driver size
    Quote Originally Posted by btjsb9 View Post
    I used to own this car(I’m pretty sure it was mine anyway) and I’m 6’2” and 240 ish. I fit without the seat insert that came with it. You are basically sitting on the floor, but that’s no problem. The extra hoop on the roll bar was for added height.
    I have had some people sit in car about your size and and the fit could be made. We removed the my foam seat and all that was left was adjusting the pedal cluster. The pedal cluster can easily be adjusted forward.
    Liked: 1486
    I'm 6', ballooned to 230. I sit on a chunk of 1/4" ensolite with a bead seat surround. Back is maybe one bead thick down the middle. The trick to the HANS fitment is to remove the stock VD thick head pads and put in something very thin. I 3d printed one out of TPU.
    As previously stated, foot size is the real big issue. I wear 13s normally, 11.5s in the car, and I go to a race store to try things on before buying. Pedals have been very carefully crafted over the years, and there's a metal plate in my right shoe to keep my foot from "flowing" around the brake pedal and holding the gas down under hard braking.
    Greer, SC
    Liked: 21
    Default Car Sola
    Quote Originally Posted by MattFV61 View Post
    1995 Van Dieman FC
    3 sets wheels
    Many gear sets
    Diffusers
    Van Diemen
    Original
    log books
    New Battery 2022
    FIA rain light
    Original wing
    Reliable car
    Needs new belts
    MK Rear Quick Lift
    Spare Body Parts
    2 Left Side pods
    1 Right Side pod
    Shock cover
    2 radiators
    A arms
    Right rear lower
    Left front lower
    Asking $17,000.00
    Located:
    Greer, SC 29651
    Car Sold
    Atlanta GA
    Car Sold
    Where did it end up going?
    Greer, SC
    Liked: 21
    Default New home for FC
    The car is now in Maryland-DC area. Will most likely run on the RIGHT Coast.
