    St Petersburg, Florida
    Liked: 31
    Default RF-95 Van Diemen Quicksilver
    RF-95 Van Diemen - Quicksilver Pinto chassis # 2107
    Bought this chassis to restore and use for doing new suspension and aero updates. This car is being reassembled with a lot of new components,as well completely refurbished for a performance upgrade. In the fall of 95 we built and tested a wide track version and the results were super positive. However after a trip to the VD factory we decided to build what was the 96 Monoshock chassis. Have always wanted to re-visit this and have taken it a step further with a w-base extension. Chassis also has updated front and rear wings as well as new diffuser. With the new Pinto Power could be at the front driven correctly.
    New "Von Demon" Wide track 4"wider / Long wheelbase suspension 2" longer
    Blueprinted gearbox with new alloy diff and CWP geared for Road Atlanta, case and adaptor housing coated in Cerakote
    Magnesium uprights rebuilt,new Wilwood LD-20's on drilled rotors,[incredibly light corners 4lbs lighter than modern Van Diemen]
    Fresh Penske 8760 triples with updated internals, mechanical front droop limiters
    New Alloy Rads
    New ABS Floors
    New AIM Data logger
    New Sparco Wheel and Belts
    2 Sets of freshly powdercoated OZ wheels with new wets and drys
    ATL Fuel cell with Filters and Pump out kit
    All new Summit Plumbing, oil, water, brakes, clutch, fuel
    New nosebox in honeycomb with new battery
    Refurbished as new steering rack, coated in Cerakote
    Can have a choice between Stainless or Alloy floor, 12lbs diff
    Bodywork is bare ready for paint can be sprayed any color.
    17,500 can deliver anywhere. 727 743 6725
  2. The following 7 users liked this post:
    Member Yzracing159's Avatar
    Wisconsin
    Do you have any pictures
    Liked: 31
    Morning, apologies trying to get out in front, components only, chassis a starting to be reassembled for delivery first part Jan. Have too many racing cars/projects and more arriving need space in a small workshop. Will post photos once it is more complete.
    Vancouver
    Would you sell the package un assembled?
    thanks,
    James
