    Ridgecrest, Ca
    Liked: 259
    Default oil to water heat exchanger
    looking for recommendation(s) and source for a small oil to water heat exchanger for use on a Kent. something "thin" in one direction would be perfect for mounting in front of the engine....
    thanks in advance for your thoughts.
    Art
    artesmith@earthlink.net
    Reno, NV
    Liked: 30
    Suggest to take a look at the Laminova style coolers.
    https://irp.cdn-website.com/e112be6e...aminova523.pdf
    Ridgecrest, Ca
    Liked: 259
    Quote Originally Posted by Joules5 View Post
    Joules-
    thanks, exactly what I was hoping for!!
    Art
    Liked: 799
    You see these on lots of cars. There can be a little trial-and-error involved in getting the correct size for your application, balancing heat transfer and resulting steady-state fluid temperatures.
    So many assumptions in the calculations make a detailed analysis difficult.
    (note even the supplier webpage declines to advise on size choice)
    Liked: 942
    I believe DaveW uses an OE Ford spin on oil cooler that sandwiches between the filter housing and the filter.
    Liked: 3279
    That was with the Pinto engine. I now use one from C&R that Citation installed in 2008. It is the long aluminum piece below. The sandwich cooler was very effective on the Pinto and before that on the FF.
    Numbers on the C&R heat exchanger are:
    CB 6-26-08 (probably made by "CB" on that date)
    W.O. 65719-01
    It's 15" long w/o the water fittings on each end which are 1.25" dia x 1.5" long. It's 2.75" wide x 1.5" thick, plus the 2 oil fittings on top near each end.
    Ridgecrest, Ca
    Liked: 259
    Ian / Dan / Dave-
    thanks guys, Dave's 2-liter design point helps a bunch with my initial guess on sizing!! my potential application is a basic frontal area (ie: drag) for hose routing nightmare trade
    Art
