Results 1 to 11 of 11
    Contributing Member cgscgs's Avatar
    Indianapolis, IN
    Liked: 39
    Default Speed Bleeder question
    Seems like a speed bleeder might solve a tricky slave cylinder bleeding issue, but I have a question. The threads come with sealant applied. When I re-use the bleeder screw do I need to refresh the sealant? If so, is there a recommended sealant? Thanks!
    Danbury, CT.
    Liked: 1898
    Speed bleeders suck.
    Get a brake bleed bottle from Pegasus.
    Attach to bleeder
    Open bleeder
    Pump pedal till no bubbles come out.
    Close bleeder
    Move on with your life.
  3. The following 7 users liked this post:
    Liked: 1474
    Interesting. I've put them on every set of calipers I've had for more than 20 years with no issues. I even built a setup to bleed all 4 at the same time.
    What makes you say they suck?
    Destin FL
    Liked: 645
    Yep
    Attach to bleeder
    Open bleeder
    Close bleeder
    V/r
    Iverson
    Cumming, GA
    Liked: 215
    Quote Originally Posted by cgscgs View Post
    I've never re-sealed mine and they work fine.
    Sam Lockwood
    Raceworks, Inc
    www.lockraceworks.com
    CA
    Liked: 246
    Default Earls speed bleeders
    I actually prefer the earls speed bleeder as they use a spring loaded brass plunger and do not rely on any thread sealant. Have used them on multiple cars for many years with no issues.
    New Jersey
    Liked: 39
    Same here. They work great.
    New Jersey
    Liked: 39
    I replace rather than reuse. They aren't very expensive, and it gives me peace of mind to replace them.
    Liked: 4346
    Attach to bleeder
    Open bleeder
    Close bleeder
    I use a Gatorade bottle with a wire hanger hook and surplus hose. One man bleeding for 30 years and no problems.
    Gravity is our friend.
    But people like buying gadgets
    And of course, other people like selling gadgets.
    Liked: 3279
    Attach to bleeder
    Open bleeder
    Close bleeder
    I use a Gatorade bottle with a wire hanger hook and surplus hose. One man bleeding for 30 tears and no problems.
    I bleed (and replace fluid) on everything this way including our street vehicles. The trick to make this work is to have the bleed line go up from the bleed screw before going downward into the bottle. That prevents air from being sucked back into the system on the release stroke. Currently I'm using an old quart milk bottle to bleed into.
  14. #11
    Tempe, AZ
    Liked: 1112
    An unbroken fluid column does prevent air entrainment. Until the hose pops off the nipple mid-stroke. Speed bleeders avoid that problem.
    Caldwell D9B - Sold
