Results 1 to 9 of 9
Thread: Vector starter
    Peninsula, Ohio
    Liked: 108
    Default Vector starter
    Hey all past and present vector owners.
    Looking for a starter. Kent 1600 installed now.
    Any info / part numbers appreciated
    Don
    Senior Member Dan Pyanowski's Avatar
    Green, Ohio
    Liked: 54
    Hi Don
    From the looks of the bell housing and bolt pattern, the starter required is nothing special.
    look on eBay for Wosp starters:
    “Lotus Cortina MK1 MK2 9 tooth 2 bolt high torque slimline starter motor”
    Wosp #LHS269-9-2
    There is also a 3 bott which would be ideal for you car.
    Check the number of teeth on the flywheel. If 110, then use the 9 tooth pinion.
    if 130, then use the 10 tooth pinion.
    say hello to Pierre for me.
    Dan
    Peninsula, Ohio
    Liked: 108
    Default Wosp
    Will do
    Derbyshire, United Kingdom
    Liked: 313
    Harrow, Ontario CA.
    Liked: 14
    Quote Originally Posted by djones View Post
    Will do
    Dan has given you a good place to start.
    Origanally my Vector had an off the shelf, 3 bolt starter, at the time my starter guy could not source parts for it, so I went with a Super Starter.
    My problem...back in the day I had to have an adaptor made.
    These days you probably will be able to find the exact starter for you application.
    I did look for my old starter to see if it had a make and possible part number for you, but alas no luck.
    Regards
    Dave
    Contributing Member emackey's Avatar
    Maple Grove, MN
    Liked: 20
    Default Marc Bushman
    Call Marc Bushman. 630-279-8834
    Peninsula, Ohio
    Liked: 108
    Default Thanks
    Thanks to all who replied. Starter on the way
    New Mexico USA
    Liked: 58
    Who had the magic part?
    Peninsula, Ohio
    Liked: 108
    Default Ebay
    Ebay. Can't remember the last time I did that. WOSP lotus cortina starter.
    Fingers crossed
