Strong enough?
Strong enough?
Well, size matters
I think this has been discussed in the past. IIRC, the reason you might go to aluminum is weight savings, and that savings over CM tube is negligible if any. 6 ft of 4130 at 5/8 od with 049 wall is less than 2 pounds.
YMMV
I have a vintage Porsche racecar that has an aluminum shift rod - something like 3/4" or 7/8" OD .125" wall. Seems to work fine, though that's probably thicker than it needs to be. I dealt with some ovaling of the holes where the U joint bolts to it. I wondered if the softer aluminum made it more susceptible to this, but a thinner wall steel tube might have a similar result. If the holes are sized correctly in the first place and everything is kept tight, it probably shouldn't have been an issue in the first place.
Either steel or AL will work, but it's a matter of which is more important to you - weight or compact size. As stated above, the weight savings is negligible, and alloy steel will be more robust, especially at the fasteners.
I will take CM in the biggest diameter that will fit in my application (and which I can afford the joints).
Fellas;
So here’s the deal. I fell into a terrific bargain on some MS Apex joints, and thought replacing the OEM shift rods (serious overkill, and hefty in weight) with CrMo 0.50” OD tubing (that I bought). The problem is the tubing is within the +/- specs, but the OD dimension is greater than the precision of the ID of the bearing.
My thought was to switch to Al tubing with a closer tolerance. Thoughts?
IMO, any 1/2" OD aluminum tubing will likely have issues with yielding, especially at the fastener locations. If you are certain you want aluminum, I'd go with solid 7075 (73 ksi yield) rod like this at McMaster-Carr: https://www.mcmaster.com/90465K73 .
Even that may have wear issues where it rides inside the guides and with that small diameter, yield and create rotational play at the fasteners.
Thanks for the correction DaveW! Like others I misunderstood that it was the tube & joints that didn't work together...
Depends on where the joints are in relation to the support bearings though: If joints are immediately next to the bearings, then using short stubs machined to suit the latter, with CrMo for the long straight runs should be possible.
Are the support bearings bushing types?
Sandpaper will knock 3 thou out real quick....
Even better, a small hone if you have it.
The VD use swivel joint/spherical bearings like this: https://www.mcmaster.com/63195K16/
Most of the action is sliding.
I replaced some once in my 94/95 and it was easy to fit them with some sandpaper and polished both the rod and the bearing.
Sure, but I've knocked 3 thou off with sandpaper many times to fit something and it's really not that difficult. Roll the paper up to several thicknesses, insert into the bushing and work it a bit in several directions. Use a 150 and then finish it with something like 220.
Opening up the bearings sure sounds like the way to go. Much easier and less expensive to do than tubing diameter reductions.
"or small standing drum"
Very good idea.
