Results 1 to 5 of 5
Thread: RT-5 Ring gear.
    Senior Member SV@RHC's Avatar
    Livermore, California
    Liked: 63
    Default RT-5 Ring gear.
    Any body know were I can find a 113 tooth ring gear for a Ralt RT-5?? anyone??? Bueler???
    Member bobmic's Avatar
    So California
    Maybe Tilton since they make flywheels.
    Sacramento, California
    Liked: 95
    Did the starter eat the ring gear too? I took a picture of the Bosch numbers on my starter pinion. Send me a pm with your email and I’ll send you the pic.
    Liked: 63
    Default Starter and ring
    The ring gear doesn't look to bad but I can see that eventually it will need to be replaced. I'll send you a PM. Margraff has a starter guy that thinks he can repair the Bosch unit with a new pinion but I would still prefer to go with a Tilton.
    Liked: 63
    Default a little more info
    Still no luck trying to match up. The Outside diameter appears to be about 9.5" hard to tell due to tooth were. The inside diameter appears to be 211MM. The gear height appears to be about .690 again due to were. the ring thickness appears to be .340.
    Not sure where to go from here. maybe an all-new system, ring gear, flywheel and starter is the answer???
