Results 1 to 23 of 23
    Destin FL
    Liked: 645
    Default Extremely High Misalignment Bearing
    Gents;
    I am in search of a high misalignment bearing equivalent to the NMB ART7ECR. These are stock dimensions:
    Ball center to end of thread: (A) = 2.125"
    Ball bore diameter: (B) = 7/16"
    Thread length: (C) = 1.281"
    Head diameter: (D) = 1.150"
    Body width: (T) = 0.452"
    Ball width: (W) = 0.562"
    I need T quite thinner. Any help?
    V/r
    Liked: 799
    how much thinner can "T" get before the ball wont stay in?
    how about a wider clevis with std bearing and some reducers/spacers instead?
    Liked: 139
    FK makes a JMX-T that is .437. Their HJMX is .355 but the ball is wide, maybe machine the sides off the ball.
    Derbyshire, United Kingdom
    Liked: 313
    Normally high misalignment bearings are achieved using an oversize shank and necked ball, eg. 7/16 bore will have a 1/2 thread, eg:
    https://www.pegasusautoracing.com/pr...p?Product=3064
    Liked: 799
    never seen this concept before, looks like a stepped(?) body
    https://www.speedwaymotors.com/QA1-P...oaAvQ7EALw_wcB
    Liked: 1397
    Default Aurora Bearings
    Arizona
    Liked: 323
    Default Sources for High Misalign
    If you are searching for High Misalign, you need to search areas where this is commonplace.... offroad. Below is an online offroad parts supplier.
    https://www.pacificcustoms.com/mm5/m...w=&range_high=
    Prescott, AZ
    Liked: 182
    Replacement or re-engineering? Might be a simpler way?
    Destin FL
    Liked: 645
    Ian, this may very well be the ticket.
    To all that contributed, my most profound thx.
    V/r
    Port Angeles, Wa.
    May also want to check out Rod End Supply
    Liked: 1397
    Default Super Swivel Rod Ends
    Take a look at this rod end. MeMaster-Carr sells this product:
    https://www.mcmaster.com/products/be...nt-rod-ends-9/
    Destin FL
    Liked: 645
    Gents;
    With your help, I found one with “T” at 0.225”. Going to require some milling on the ball extensions, but I will be able to at least bump steer 3” north and south.
    BTW, what is the anticipated basic vertical movement from center of an RF-95?
    Gents;
    V/r
    Sacramento, California
    Liked: 95
    Narrowing “t” quite a bit. My worry would be about the loss of load bearing capability. Hard to calculate but something to consider.
    Liked: 313
    Gents;
    Why would you need to change from the original bearing, which would have been spec'd to accommodate the movement?
  17. The following 3 users liked this post:
    Liked: 799
    Gents;
    +/- 3" ??
    what front ride height requires you to worry about 3" of compression?
    also occurs to me that a wheel in 3" of droop will likely have so little load on it that steering delta wont matter;
    wonder if this bearing search is necessary? as previous poster asked, why are you not using it as-designed?
    Destin FL
    Liked: 645
    Fellas;
    Photos and an explanation from my feeble understanding tomorrow. Bare with me.
    V/r
  21. #17
    Liked: 1397
    Default High misalignment inserts
    Recently I was working on a new front upright for a Citation where I needed to have a horizontal bolt for the top of the upright. I found the following inserts for spherical bearings that gave 60 degrees of misalignment. these were the perfect part and were what I needed.
    https://www.mcmaster.com/products/rod-end-inserts/
  23. #18
    Liked: 270
    Default Rod End
    Maybe in my old age I get to ask - why do you need this angularity anywhere on an RF95.
    Phil
  24. The following 4 users liked this post:
  25. #19
    Destin FL
    Liked: 645
    Ian;
    My understanding for the typical bump steer was +/- 3". Correct me, Sir. What is typical for an FC, please?
    +/- 3" ??
    V/r
  26. #20
    Destin FL
    Liked: 645
    Phil;
    A picture is worth a thousand words. But I was violently ill last night, and my surmise was food poisoning. Still recovering, but when I am semi good-to-go, I will post exactly my conundrum and solicit your thoughts.
    Quote Originally Posted by Phil Creighton View Post
    Phil
    V/r
  27. #21
    Destin FL
    Liked: 645
    Gents;
    I inserted the original rod end bearing into my camber adjuster link, and noticed the full bearing up sweep from neutral is about 0.045", and the full bearing down sweep from neutral is approximately 0.045".
    Additionally, the total movement from the of the beginning of the threads is approximately 0.75", however the face of the locking nut that makes contact with the A-frame is about 0.75" from the end (everyone knows I suck at math).
    From Primus:
    Front ride ht: 28mm
    Rear ride ht: 38mm
    From 10/Tenths
    Front 29-35mm (mid ~ 1.25")
    Rear 39-45mm (mid ~ 1.65")
    Rake 10-12mm
    Thoughts?
    V/r
  28. #22
    Liked: 702
    Rick,
    I can tell you from about 10 years of experience on my own cars and even more on customer cars, there is no need for anything other than the rod end that I suggested. The range of motion and clearance to the camber link is no different than every Van Diemen built since 1997. I guarantee you will not have problems.
    www.gyrodynamics.net
  30. #23
    Destin FL
    Liked: 645
    Mike, then I will continue as you suggested. Steady as she goes, Sir.
    Rick,
    V/r
