Results 1 to 9 of 9
    Benicia, California
    Default metalastic bushings
    Hello I need new metalastic bushings for the engine mounts on my 71 Hawake DL2B. Appear to be 1" ID, 1" long with a1/2 bolt . Anyone have a source for these?
    Thank you
    Lincoln NE
    Liked: 85
    GMT / Lee Chapman has a good selection
    Dave Bean also has a limited selection
    Benicia, California
    Thank you
    Liked: 803
    I found some years ago from a supplier of vintage Lotus 7 parts. Can't recall their name, maybe in Pennsylvania?
    Default A substitute
    Years ago I ran into a similar problem with needing a metalastic bushings. I found that I could substitute leaf spring bushing. It did take a sleeve or 2 to make the substitution but it worked well. I needed it for the engine mounts on my Titan Mk6.
    Liked: 855
    I'd guess it was R.D. Enterprises:
    https://www.rdent.com/
    Benicia, California
    Default Thank you
    Thank you
    San Diego,Ca
    Liked: 492
    Default bushings
    Check with Neil Porter. He is pretty local to you 209-722-7373
    Roland Johnson
    San Diego, Ca
    Benicia, California
    Quote Originally Posted by Roland V. Johnson View Post
    Thank you
