1999 Green Ford F350 4 Dr. Dually 7.3 Deisel
175,000 miles, Automatic
6 new tires ($1,000)
New brakes ($2,000)
Trailer brake controller ($100)
Diablo chip ($600)
New OEM turbo ($1,000)
BANKS turbo power pipe and complete 4" turbo back exhaust system and bigger waste gate actuator ($2,000)
New tourque converter and new updated transmission ($2,650)
New windsheild ($350)
Sprayed in bedliner ($350)
Heavy duty tag hitch w/ trailer stabilizer bar attachment ($500)
New main ECU ($400)
New Front Hub Bearings
KBB is $17,500 for a truck that needs work.
Will sell for $16,500. This truck is mechanically perfect.
1994 Pace Black 24' Tag enclosed trailer, 6'3" inside height, beavertail, b&w cherkboard floor, 48" main side door, 60" side door over drivers side wheel well, e-track on floor full length, e-track on walls, dual rear tire racks in rear up high (holds 16 mounted wheels) Front shelves, rack for fully assembled platform at ceiling height, dual 5200 lb. axles, (5) 1 season old tires including spare. Have put two Zetecs on floor w/ noses off. Some exterior blemishes but in great overall shape. $4,500
Will sell complete package for $18,500 obo.
All trailer tire racks, shelf systems and platform rack are made using aluminum shoring beams rated at 2000 lbs. each. Did not use 2 x 4's. Beams alone are worth $900 and already have e-track connections at ends, They can be moved around in many configurations. There is a picture of the trailer in the f2000.com event results forum under "2003 ARRC". It is the fourth picture down.
Call Marshall Aiken @ 770-337-5458
The turck is in the shop having the new windsheild, new turbo, transmission, tourque converter, bearings and ECU replaced. The bill for this work is $3,500.
[size="1"][ November 12, 2003, 10:06 AM: Message edited by: sprcr21 ][/size]
