Results 1 to 17 of 17
    Member Schmaz356's Avatar
    Richland, Michigan
    Default Wanted - Hewland Side Plates for Lotus 51
    I'm looking for a good pair of Hewland Side Plates that fit a Louts 51. These have rear facing ears and need to fit and MK8/9. Thanks.
    Liked: 271
    Default Mk 8 Sideplates
    I think I have a pair - I did own a couple of 51s 20+ years ago. One was renault box other hewland. I would need to see a picture to confirm these are correct. They are with an early VW case.
    Phil
    Michigan
    Liked: 238
    If Phil doesn't have them I do.
    Liked: 271
    Default Lotus sideplate
    I will take them off the early VW case that they are on and take pictures tomorrow - looks like someone started a project and never got very far. $500 for the plates if they are ok.?
    Phil
    Tacoma, WA
    Liked: 323
    Are these the ones you are looking for? Not mine, but saw them on ebay
    https://www.ebay.com/itm/15567800740...Bk9SR5jIi7SxYg
    -John Allen
    Tacoma, WA
    '82 Royale RP31M
    Liked: 271
    Default Ebay
    Ebay says these are forward facing. Mine are on the gearbox case so I need to check if they are truly rear facing as they look very similar
    Phil
    Liked: 433
    Quote Originally Posted by scorp997 View Post
    Those are the right configuration but don't fit a MK8/9. Good price though.
    Graham
    Tacoma, WA
    Liked: 323
    Diff bearing different?
    -John Allen
    Tacoma, WA
    '82 Royale RP31M
    Liked: 271
    Default Sideplates
    OK mine are the same as the ebay set. They were bolted on the early case on the wrong sides.
    Liked: 433
    John, it says they don't fit a mk 8/9 further down in the ad. Only a 4,5,6. I would think the attaching bolt pattern would be the same as the all use a VW case, must be the axle or bearing size.
    Graham
    Petaluma, CA
    Liked: 565
    The 4/5/6 use a single row ball bearing for the diff, the 8/9 use taper bearings. So the bearing pockets are different dimensions. This isn't the end of the world, a good machinist can sleeve the sidecovers to utilize the taper bearings quite easily.
    Ethan Shippert
    https://www.norwestff.com
  12. The following 4 users liked this post:
    Destin FL
    Liked: 648
    I have an NOS R/H side plate. PRISTINE, absolutely perfect in every respect. PERFECT.
    Richland, Michigan
    Default Lotus Hewland Side Plates
    Quote Originally Posted by Gordy View Post
    Do you still have these side plates? I just saw your reply. These need to be rear facing to fit a Lotus 51. Currently my car has the Renault gearbox but I do have a Hewland. Where are you located. I'm in SW Michigan.
  15. #14
    Michigan
    Liked: 238
    Yes, I have the side plates. I'm in Bay City. I'll PM contact info.
  16. #15
    Richland, Michigan
    Default Lotus Side Plates for Hewland
    I sent you a PM but am unsure if it went through.
    You responded to a post I had in July or August about side plates I was looking for. Do you still have them? The ones I purchased unfortunately were not for a MK8/9 so they do not work. I am still looking for these but they must fit this gearbox. Let me know. Thanks.
  17. #16
    CA
    Liked: 246
    Quote Originally Posted by Schmaz356 View Post
    Can you clarify what you mean by don’t fit. Are you referring to the stub axle bearings as mentioned by Ethan, or is there some other issue. I ask because I am looking for the opposite (Brabham configuration) extended ear side plates for an F3 project. Todd
  18. #17
    Winter Garden, Florida
    Liked: 160
    If you can't find them used, you may want to consider new ones sold by GMT Racing.
    Cheers, Joe
    http://www.leechapmanracing.com/lotus_51.html
