As much as it is great to see all the comments so I can get a better understanding where my fellow racers' mindsets are at, unfortunately there is a lack of consistency. I will just leave this here from the June 2023 GCR
B. YELLOW FLAG (Solid Yellow)
STANDING YELLOW – You are approaching an incident where your and other’s safety are at risk. Theracing surface may be clear but there is immediate danger to you or others if you left the racing surface.Slow significantly and proceed through the incident at a reduced speed (emphasis added). There is no passing from the flaguntil past the emergency incident.
WAVED – You are approaching an incident that has great danger to you and others. The racing surfacemay be partially or completely blocked. Slow significantly and be prepared to stop (emphasis added). All efforts should bemade to proceed through a Waving Yellow Flag in single file order. There is no passing from the flag untilpast the emergency incident.The no passing zone starts at a perpendicular line across the track from the flag and ends at a perpendicularline across the track from the last component of the incident causing the yellow flag. The last componentmay be the car, driver, responding officials, other vehicles and/or large debris.
DOUBLE YELLOW, DISPLAYED AT ALL STATIONS – Indicates the entire course is under yellow (full courseyellow). All stations will display double yellow flags for all pace and safety car laps. SLOW DOWN, NOPASSING. However, cars may carefully pass emergency vehicles and other cars that are disabled or offpace (see 6.6.2.).NOTE: A driver may encounter several flags before reaching the emergency area. The requirements are stillthe same: SLOW DOWN, NO PASSING.
For those who want to argue against the rules, feel free to do so.
As for the recent incident at June Sprints:(i) there was a standing yellow back in the carousel --> drivers continued on flat out.
(ii) there was a waving yellow in the kink --> Drivers continued on flat out.
Facts are facts on that aspect.
