Results 1 to 6 of 6
    Junior Member argojm14's Avatar
    Netherlands
    Default Argo JM14(b) or Royale RP39 info wanted
    Hello there,
    I'm looking for other owners or people who know or have information about the Argo JM14 aka Royale RP39 FormulaFord2000 cars.
    I have two cars, one is a 1983 regular JM14 and the other is an 'extended' 1984/1985 JM14b.
    Any information is more then welcome,
    Regards from The Netherlands
    Paul
    Woodinville, Washington
    Default Argo JM14
    Quote Originally Posted by argojm14 View Post
    Hello there,
    Paul
    I had one of these for a while. I did not like the orientation of the rod ends on the upper front suspension to upright joints, in that they limited the amount of steering lock available. There were spacers on the steering rack to limit the steering range so that the rod ends would not be broken. As a result, extreme oversteer recovery was limited. This not supposed to be a problem, but sometimes it is needed.
    Netherlands
    Quote Originally Posted by Victor Munsen View Post
    Did you have the JM14 or the longer JM14b version ?
    When looking at both chassis I see thee is some difference on the front end specifically to make room for bigger shocks
    I am sorry to say that I responded incorrectly to your inquiry. The vehicle I owned was an Argo JM17 (serial # 114, I think). My description therefore is not applicable to your inquiry.
    Liked: 1488
    Try Alan Cornock at Fulmar Competition Services in the UK.
    Netherlands
    Unfortunately Alan does not have anything about the Argo JM14.
