Results 1 to 6 of 6
    Pittsfield, Mass.
    Default Input shaft/spline identification
    Hi all,
    I am trying to determine the original application for the transmission/input shaft on
    my transmission, a Hewland JFR. The spline diameter and teeth are 29/32 x 17 teeth. The clutch in the
    car is an OT 2 Tilton, and I was hopeful to simply subsitute a disc with the appropriate
    splined hub and be good to go. If anyone knows what the 29/32 x 17 spline was original
    equipment in please let me know. Tilton did not have the tooling to produce this spline
    so I am investigating having one made custom for this application by another supplier.
    Regards,
    Guil
    Liked: 3279
    Pittsfield, Mass.
    Default Clutch question
    When I put a caliper or micrometer on the output of the trans
    I am getting a smaller dimension, about .908, Do you think that
    because of the odd number of teeth I am seeing the slightly smaller
    measurement than the one spec'ed for the srt4 disc?
    Thanks for your input Dave!
    Best,
    Guil
    Liked: 139
    Default Dodge 2.4?
    17 spline x 23mm or .940
    Wild stab in the dark
    Liked: 3279
    Quote Originally Posted by gtwiss View Post
    Best,
    Guil
    Just a guess, but some of that difference may just be clearance needed for letting the disc move freely on the shaft.
    And you are correct that an odd # of teeth will make the shaft measurement a few thousandths smaller. A calculation of a 17-sided polygon gives 0.932 measurement for a 0.940 OD circle. So 0.932-0.908 means ~0.024" for clearance.
    Liked: 270
    Default Jfr
    Is this one of the ex Skip Barber boxes - probably was a dodge if so
    Phil
