Results 1 to 12 of 12
    Eugene, Oregon
    Default What magnesium fill rod
    Hello,
    I'm intending to TIG weld a crack in my VW Rhino magnesium transmission case. Could someone help me with a recommendation on what fill rod to use? AZ92A seems to be the "catch-all" fill rod but I thought I'd ask the experts. Searched the forum but no luck.
    Thank you
    1972 Merlyn Mk 20
    Tacoma, WA
    Liked: 323
    May be wrong, but I believe Rhino cases are aluminum and not magnesium
    -John Allen
    Tacoma, WA
    '82 Royale RP31M
    Prescott, AZ
    Liked: 182
    Both were made. Mag is very difficult to find, probably discontinued.
    New Mexico USA
    Liked: 59
    Default Welding alloy for Hewland trans case
    It might be worth contacting Hewland Classic via email for such technical info. They were very forthcoming re FT200 case material alloy for me several years ago. They confirmed the FT200 case is RZ5/ZE41 mag. I then went to Magnesium Electron for the recommended RZ5 filler rod.
    I recall that the VW based cases have considerable aluminum in their alloy, unlike FT200s that have a fairly "pure" magnesium alloy with minimal aluminum.
    Hewland classic is at ---
    Home ==> http://www.hewlandclassic.com/
    Email ==> sales@hewlandclassic.com
    Lee
    PS -- others would likely be interested in what you find out, so please post up results in this thread!
    Eugene, Oregon
    Default Fill rod
    Quote Originally Posted by Lee Johnson View Post
    Lee
    Thank you very much! I sent an email and will let you all know when hear back. I'll do the white vinegar test as well to see if it has a lot of aluminum, just for kicks. (it fizzes if it's mag)
    Cheers!
    1972 Merlyn Mk 20
    Winter Garden, Florida
    Liked: 160
    You could also try asking on the Hewland Facebook page if you are not successful with Hewland Classic.
    https://www.facebook.com/groups/53024475501
    Liked: 433
    On a magnesium VW case I had it welded with AZ61A. Never had any problem. Just my 2c.
    Graham
    Eugene, Oregon
    Default Mag fill rod
    Ah, someone who's done it. Thank you.
    I contacted Hewland and Taylor, they've never welded a mag case.
    1972 Merlyn Mk 20
  13. #9
    Sydney, Australia
    Default ZE41 (RZ5) Magnesium Welding Rod.
    I am looking into ordering the ZE41 RZ5 filler rods at the moment from the only supplier world wide. RZ5 is a proprietary product. The advice I have had is the commonly avail mag filler rods are very different in chemical composition to RZ5, So if you need to repair a more expensive Hewland case such as an FT200 , FG400 or DG300 you will require the uber expensive RZ5 filler rods.
    Happy to help out others with supply of this filler rod once I have them in hand, The min order is 2kg or 4.4 lb's which hopefully I will never use up. Thanks to Lee for a point in the right direction.
    Lee
  16. #11
    Eugene, Oregon
    Default Re; mag fill rod
    Thank you,
    I haven't moved on this yet, too busy with work. I'll update when I do.
    1972 Merlyn Mk 20
  17. #12
    Sydney, Australia
    Liked: 146
    Last time I had to fix a Hewland case, I found that I needed to buy 5 kg of rods.
    It was easier to find a Formula Vee guy, who claimed that the VW crankcase could be welded with the same rods. Worked a treat, 20 years later, no issues.
