    Gambier, Ohio
    Default AIM MXL Dash - RPM
    If anyone can tell me how to hook up the RPM to the AIM MXL Pista dash I would appreciate it.
    Liked: 286
    You would connect the tacho output from your MSD ignition to Pin 8A (small connector) (RPM input) on the Pista harness. I would expect there is an RPM input wire in the harness. Here is the wiring documentation for the MXL Pista;
    https://www.aim-sportline.com/downlo...ta_102_eng.pdf
    David Ferguson
    Veracity Racing Data
    Shift RPM App for iOS
    805-238-1699
    Gambier, Ohio
    Default Rookie
    The RPM white wire from the AIM unit (labeled RPM) plugged into the output MSD unit made it work. I had no faith in the MSD output connection as the old STACK dash had no RPM reading. I hesitate at just trying stuff as damage is almost sure to occur. Thanks, David for giving me the courage. This most likely won't be my last stupid question.
    Liked: 286
    There are no stupid questions, only stupid answers!
    David Ferguson
    805-238-1699
