Results 1 to 5 of 5
    Senior Member Raleigh's Avatar
    Sydney, Australia
    Default Ralt RT4 Engine Mount reproduction E.O.I
    With all the chatter of RT4 owners requiring the the RH front engine mount casting that bolts to the BDA Ford / 711M / 831C engine block I am seeking actual firm E.O.I numbers to make it affordable to reproduce the mount. The other mounts are sheet metal alclad which any shop with a folder can reproduce, I wont be doing them but can supply photos if required.
    This job will require 3D scanning / Modelling , subsequent file to run the CNC equipment & Trial production test fit samples Which comes at quite the price, at least it does in the land of Oz.
    I am on to my 3rd CNC shop which is actually showing interest in lower volumes.
    The sample is a Genuine Cast alloy Ralt item.
    I am doing this as a service to the Ralt RT4 community not a money making exercise, Moderators please delete if considered commercial.
    Confirmed E.O.I numbers: 0
    Late Braking Member
    Danville, California
    Liked: 217
    When you have the 3D file ready, you can get a quote from this place https://www.protolabs.com/
    I use them for high quality 3D printing as well as aluminum CNC work. Prices for one-off stuff isn't that bad and I've never had a quality issue.
    I'll update this post in the next day or so with at least one vendor in China that does the same type of work for a lot less money.
    Sydney, Australia
    Default Ralt E.O.I
    Thanks for the interest Steve, Are you in? I have a Local shop to do the 3D scan and CNC work. I am throwing this out to the community to see if there is enough interest to cover the R&D costs. If not, no harm and the mount goes back on the RT4 Chassis.
    Late Braking Member
    Liked: 217
    Quote Originally Posted by Raleigh View Post
    Unfortunately, I'm not interested. I'm just a geek that runs a product design house that does (among other things) reverse engineering and small run manufacturing.
    While I was seriously tempted by the RT4 that was advertised here on Apex last month I decided I was better off to continue with my Swift DB2 that I just finished restoring last year.
    Sydney, Australia
    Default USA Production.
    Charles Warner has just obtained pricing to have the RT4 engine mounts made in the USA at a much lower price than I could achieve in Oz. This E.O.I is now Closed.
    I will be supporting the production run and purchasing from Charles myself. Thread link Below:
    https://www.apexspeed.com/forums/sho...130#post649130
