Results 1 to 16 of 16
    South Carolina
    Liked: 673
    Default cheap FF transport wheel options?
    Okay, I am losing my shop, and to add insult to injury, it looks like my new driveway has too much angle to roll the car from the road into the garage. Just to rub salt in the wound, I sold my spare set of rims during the "decluttering" phase... So I am looking for cheap options for transport tires that will give me some increased ride height. Any suggestions?
    Swift DB-1
    Danbury, CT.
    Liked: 1904
    A set of junk wheels and the tallest 13" tires you can find on Amazon pumped up to 50psi
    That's what I did for my RF81 and it gets me about 4" of ride height.
    Liked: 1480
    years ago I heard that 80's VW golf rims have a center hole and bolt spacing that works without a lot of extra trouble.
    San Francisco
    Liked: 77
    Default Paddock wheels
    Look into Miata wheels. I had an FE long and they worked somehow.
    Hybels
    Peninsula, Ohio
    Liked: 108
    Default Cheap
    While in a pinch I made a set for the front from plastic wheelchair wheels. Found a $50 chair on Craigslist. For me raising the front was enough as the rear is seldom the problem.
  9. #6
    Santa Cruz, ca
    Liked: 183
    Can you back the trailer up to the garage? Then use ramps to get the right angles you need. That's what I had to do when my shop space changed.
    Liked: 3287
    Quote Originally Posted by swiftdrivr View Post
    Can you back the trailer up to the garage? Then use ramps to get the angles you need. That's what I had to do when my shop space changed.
    I don't have transport wheels, so that's what I do - there's no way I can roll my F2000 out of the shop at all with 1" ground clearance.
    South Carolina
    Liked: 673
    Unfortunately, the new house comes with a very short driveway and a road far too narrow to back up the rig at any reasonable angle to off load the car that way. Fortunately, I live near a junk-yard, so maybe I can find some cheap steel rims to match the Swift's bolt pattern.
    Swift DB-1
  13. #9
    Liked: 3287
    You could try to find 15 or 16" mini-spare wheels. Probably a dime a dozen. May even have tires on them.
  14. The following 2 users liked this post:
  15. #10
    Liked: 1480
    less cheap (maybe) is to find some old drum-brake front dirt bike rims. I think they are 19 to 21 inches. Remove the drum hardware and drill the plate for the center spud and drive pins. Use chinesium dirt bike tires and tubes.
  16. The following 3 users liked this post:
  17. #11
    West Union, IL USA
    Liked: 319
    +1
    (Extra cool points for Borrani Records off of an vintage Moto-Guzzi Ambassador or Eldorado.)
  18. The following 2 users liked this post:
  19. #12
    San Diego,Ca
    Liked: 491
    Default wheels
    Triumph Spitfire / Herald /TR-7 etc are the 3 3/4 bolt pattern.
    Roland Johnson
    San Diego, Ca
  21. #13
    Member race14's Avatar
    Carrollton Texas
    Are you any good at woodworking?
  22. #14
    South Carolina
    Liked: 673
    Quote Originally Posted by race14 View Post
    I can build stuff, but my tool set is welders and grind wheels, not wood lathes and planers. Even the tools I have are packed. Still got a drill press and skillsaw though.
    Swift DB-1
  23. #15
    Petaluma, CA
    Liked: 565
    Jim-
    Is your swift 4 bolt or center lock? I might have a couple banged up 4 bolt FF wheels kicking around if it would help you.
    I got a set of whitewalls from Summit for our Swift to make a transport set, it has about 3.5” of ground clearance with these suckers on, plus they look pretty stylie and we get a lot of compliments.
    Ethan Shippert
    https://www.norwestff.com
  24. The following 4 users liked this post:
  25. #16
    South Carolina
    Liked: 673
    Quote Originally Posted by teamwisconsin View Post
    Jim-
    Ethan, many thanks for the offer. My car is a 4 bolt. If I can’t find motorcycle tires soon I may take you up on ithe rims. They do add some 50s hot rod vibe!
    Swift DB-1
