    Simi Valley, California
    Default Van diemen rf 92 f.c. Converted for s.c.c.a , f.x class.
    **** VAN DIEMEN RF 92 F.C. CONVERTED FOR S.C.C.A , F.X CLASS. 175H.P -215H.P OPTIONAL ENGINE ****
    Approved for competition 1996 in S.C.C.A, F2000/ F.C class, With the introduction of new regulation in S.C.C.A formula F.X class, we have developed a complete upgrade package providing older Van Diemen F.C, the necessary aero dynamic changes with additional mechanical grip of wider tires and increased horsepower.
    * Complete updated side pods with larger opening for increased air flow to radiators, wider under tray for increased aero downforce, also providing low drag over rear wheels
    * Engine upgrade .175 h.p, stock spec engine only converted to alternative induction system 40mm mikuni motorcycle carburetors with custom length manifolds, alternative ignition, valve timing.
    * Engine upgrade . 215 h.p, long rods , 2100 cc , custom pistons, alternative induction system 45-48 dcoe weber carburetors with custom length manifolds, our proprietary direct ignition system, with alternative valve timing.
    * Wider front and rear tires must be utilised with 215 h.p engine upgrades.
    * Total weight with all fluids,2 gallons fuel, no driver,with either wheel tire, engine 175 h.p - 215h.p. Combination. 1025-1028 lbs
    * Due to the limitation of the Hewland LD200 gearbox 165-175 ft lbs torque, engine output should not exceed 215 h.p.
    ( ALL OF THE ABOVE LISTED SERVICES WE CAN PROVIDE SPECIFICALLY FOR VAN DIEMEN OWNERS CONTACT US FOR FURTHER DETAILS)
    This listing is for the 175 h.p upgraded engine, with all body work upgrades as mentioned above. Ready for the track we will provide final setup to the specific needs of the driver, the only additional cost would be seat belts and hans device. The following is the list of work performed.
    * NEW(FUEL SAFE) FUEL CELL
    *STACK ST8100 DASH DISPLAY, WITH LAP TIMER.
    *COMPLETE NEW WIRING INCLUDING NEW BATTERY
    *ALL NEW FASTENERS AND ROD ENDS
    *CUSTOM (PPG) PAINT WITH ALL CORRECTLY MOUNTED DUZE FASTENERS.
    *MODIFIED FRONT WINGS AND END PLATES
    *ALL NEW FUEL, COOLING SYSTEM HOSES,FITTINGS.
    This sale will include two sets of OZ wheel. With used tires (4 fronts 20.5x 7x13) (4 rears 22x8x13)
    *** FOR SALE INCLUDING TEST DAY AT WILLOW SPRINGS $29,950.00 ***
    Spare Package Not Included In Sale Price Includes The Following.
    1) Complete 215 h.p. Weber 45 dcoe carbs, manifold, rebuilt engine, with flywheel, clutch assembly.
    1) Complete Spare Hewland LD 200 Gearbox assembly. oil tank,engine adaptor.
    2) Jongbloed Wheels with used mounted tires 22x8x13 fronts.
    2) Kodiak Wheels with (New) 22.5x10x13 rears .
    1) 16' Enclosed trailer.
    TOTAL PACKAGE PRICE. $15,950.00
    Additional Photos, Information, Complete Services We Provide. See Link Below.
    https://aandbpde.com/race-cars
    * Arrive and drive track day rental programs available for Willow Springs Raceway.
    CONTACT US FOR FURTHER DETAILS.
    (805) 859-9374
