Ok Apex community, I've already spoken with a few of you about this in the last 4-5 years, but wanted to ask the collective as my development has ground to a hault for other projects.
Has anyone ever run a dry-sumped transaxle in a FF application? I've always wondered why the heaviest oil has a bunch of gears rotating through it? Shop testing showed a repeatable 30-35% increase in how many revolutions the wheels would spin. This was just from evacuating the R&P on a mk9. I realize this may decrease with wheel speed.
The pump could be driven by an electric motor (I was using a DeWalt drill for testing). The transaxle would be lubricated by nozzles in the main case and gear case. Two 'suction' ports are needed (one for R&P, one in the gearbox). Since sensors are not allowed in the transmission, a mechanical fail-safe is necessary. I'd been working on an automatic shuttle- spool valve combo. When pressure is lost, a spring moves the spool, which drains the tank back into the transaxle reverting back to a wet-sump system.
Anyone ever ventured down this rabbit hole?
Cheers,
Scott
