Hi everyone. I acquired this set of Hewland gears from a larger spare parts lot I purchased. Most of the parts were to a Swift, so I'm assuming there is a good chance thats what this all goes to, but hoping you can help me figure out what cars or transmissions these gears would be for. Someone said they appear to be Hewland MK5. Also, while they look generally similar, there seem to be roughly 5 different types of markings on the gears, some marked "N", some marked "I", then ones with an HC5R part #, ones with no such identifier and only has numbers that just simply indicates the ratio, and then a bunch of pairs whose smaller gear is about twice as thick as the larger gear. Would these all work with the same transmission, or do I have a hodgepodge of gears?
Thanks and sorry for the newbie questions.
