My Anson is missing a short section of brake line. I wrongly assumed it was just normal 3AN. Reasearch leads me to believe it is 1/8 BSP. Can anyone confirm that from my pictures? Thank you!
Looks to be taper seat bsp. There is flat face also for Racetech gauges. Maybe convert to -3 AN ?
BSP cone angle is 30 deg, AN is 37 deg. so you might be able to check that way.
Alternatively if you have a mechanical oil pressure fitting to hand, eg. Racetech, they often have a 1/8 BSP with reverse cone fitting, so should screw onto your line without sticking.
Yes, that is a BSP fitting, commonly used on oil pressure and brake/clutch lines on cars from the UK
Thank you all for confirming.
