Results 1 to 5 of 5
    Liked: 1261
    Default Source for Dowty Washer LD200 side plug ?
    Anyone know the correct size?
    https://www.mcmaster.com/dowty-washers/
    It looks to be 5/8 ish but I have constant leakage. Looks like someone buggered the threads at some point and clean out the treads and semi-countersunk and removed about 1/4" of the threads.
    I think that is why I have a constant leak.
    Any alternative ways of sealing it?
    Senior Member ejsprint30's Avatar
    Ohio
    Liked: 76
    I bought mine from Scotty Young
    EJ Korecky
    check out my products on Facebook
    https://www.facebook.com/profile.php?id=100075564523814
    Liked: 799
    If I picture your issue correctly, it’s doubtful any size Dowty washer will seal a countersunk hole.
    perhaps try a correctly-sized o-ring trapped in the countersink. You may have to increase the size of the countersink to make this idea work.
  4. The following 4 users liked this post:
    Orlando Florida 32812
    Liked: 597
    A ton of leaks here from the bottom of the casing going on for a year and a half
    I recently.........don't ask why........had to rebuild my diff (ring/pinion) in my LD200..........and thanks to scott young at sy-gearboxes.com and Alan Oppel...everything went well.
    The lower plug had a nasty leak among other problems......so I think I've got another dowty laying around if scott can't come up with one fast enough for you. I'm here to help
    Using first a steel plug I got from the Taylor end of the racing world..... the bottom hole was extremely slowly tapped with heat and then the real plug supplied by scott was slowly screwed up into the casing after that....using the new dowty of course.
    Thanks again Scott and Alan
    Liked: 1261
    I think I've got it covered with an o ring captured by the dowty.
    What surprises me is how often people cross thread and otherwise screw up these boxes.
    Obviously over torque as well. Geez, take a beat and make sure you aren't cross threading.
