Results 1 to 6 of 6
    Senior Member Nick77's Avatar
    Harleysville, Pa.
    For Sale Runoffs Winning JDR FA/F1000
    Runoffs Winning JDR FA/F1000 - $55,000 NEW PRICE !!!!!!!!!!!!
    Formula Atlantic 2022 National Championship Car
    This JDR F1000 driven by Alex Mayer has won 7 F1000 national title championships, plus 2 SCCA Runoffs National Championships, once as an SCCA FB F1000 at Indy and this year as a Formula Atlantic at VIR, and also many Majors wins, pole positions, and lap records. This car was fresh pre-Runoffs and in perfect racing condition. Pre-Runoffs all wheel bearings, differential, differential bearings, chain, fuel filter, water and oil coolers, 4 brake calipers, 2 brake master cylinders were replaced. The Formula Atlantic engine has one race. The car has a full AIM Data System.
    Available Spares
    Engine:
    Fresh Formula Atlantic engine built by RillTech. Power commander for each engine with complete wiring harness, spare clutches, many coil packs and spark plugs, throttle bodies, water pumps ,throttle cables, clutch cable, spare drive-by-wire unit, fuel lines, fuel pump and regulator, new fuel filter, custom air box, oil filters, spare oil and water coolers. 3 sets of different size Burns Stainless mufflers.
    Body: Front wing hardware, nose hardware, wing plates, front flap, end plates front and rear, end plate shoes, flap adjuster plates, wing and flap gurneys, spare side pods and full floors, splitter, multiple diffusers. High downforce and low downforce rear wing mount and end plates, multiple lower rear wings, extra end plates, multiple upper wings and flaps. New engine cover and lower side engine covers.
    Wheels and Tires: 4 sets of wheels and tires including new and used rain tires and plenty of new and scuffed tires. Several extra wheel halves.
    A complete selection of coil springs, control arms both upper and lower for both sides, multiple front steering rods with heim joints. Multiple uprights, rocker arms and camber blocks along with numerous camber shims, spindle hubs and spindles. A selection of different rate sway bars and blades, a few sets of axles, many pushrods, a full set of tripods, housings, and boots. Spare differential carriers with multiple bearings. Complete set of brake calipers, with custom (Top Secret) caliper pistons, lots of rebuild kits, quick disconnect brake lines, master cylinders, various compounds of brake pads, brake lines, 2 complete sets of rotors, spare brake bias adjuster, wheel nuts and too many other items to list.
    Tools: Gantry lift , car stand dolly, alignment bars, spindle socket, wing mount jack.
    There are enough spare parts to rebuild the entire car or outfit another spare car.
    $55,000
    215-783-5800
    Ask for Nick
  2. The following 3 users liked this post:
    Harleysville, Pa.
    NEW PRICE !!!!!!!!
    More pictures
    St Charles, Mo
    Liked: 159
    Default great car.....priced to sell
    This car has the latest gsxr engine.
    It is a great car.....and priced to sell.
    Someone should grab it.
    Senior Member bill gillespie's Avatar
    atlanta
    Liked: 101
    Paddle shift ?
    data system?
    Spares and car at 55k ?
    Bill
    Harleysville, Pa.
    Default Mayer JDR Formula 1000/Formula Atlantic
    Hi Bill sorry for the late reply been out of touch
    The car does have the latest Aim Data system
    also has The FlatShifter system, as far as the spares they are negotiable, there are enough to almost build second car
    if you have any interest we will have the car at LimeRock on the FRP, Vintage race Memorial weekend
    Nick
    215-783-5800
    Harleysville, Pa.
    Thanks Jerry
