Results 1 to 11 of 11
Thread: LD200 Venting
    Liked: 1262
    Default LD200 Venting
    What is the correct way to vent an LD200 ?
    On my previous car, there was a vent from the topmost area (above shifter) back cover through a small tube to an overflow can.
    On my current car, there is vent fashioned into the plug above the R&P. In contains some foam and a screen.
    The issue I'm having is fluid comes out of there. If I push on the screen, the foam piece is saturated.
    It seems to me that above the R&P is one of the most violent areas.
    I can plug that, but what is the best way to vent the LD200 ?
    Orlando Florida 32812
    Liked: 605
    Plug the current vent. As of old......drill & tap a hole on top into the rear cover just above the shifter selector to which you would then place your fitting and exit line - make sure the fitting is sunk no more than the thickness of the cover material itself so as to not come close to the shifter selector. When changing out gear sets, I don't remove the fitting - I simply take the exit line out of its catch bottle.
    Senior Member kea's Avatar
    madison heights,mi
    Liked: 610
    Default LD200 vent
    I prefer your current location, but I use a -3AN banjo and bolt, plus a length of -3AN brake hose venting to the oil catch tank.(or hidden from tech under something).
    Averill Racing Stuff, Inc.
    www.racing-stuff.com
    248-585-9139
  5. The following 3 users liked this post:
    Liked: 1262
    Thanks all - for confirming I need to change this.
    I believe both methods will probably work fine.
    I'll modify the current vent (less destructive) and see how that works for me.
    Destin FL
    Liked: 647
    Keith;
    Do one for me?
    V/r
    Iverson
  9. #6
    Destin FL
    Liked: 647
    Keith;
    My fill/inspection plug will be delivered to you Monday. Do your Stuff.
    V/r
    Iverson
    madison heights,mi
    Liked: 610
    Default LD200 vent
    OK
    248-585-9139
    Destin FL
    Liked: 647
    OK
    Received my vented filler/inspection cap. ABSOLUTELY perfect.
    Thx, Keith.
    V/r
    Iverson
    Senior Member ejsprint30's Avatar
    Ohio
    Liked: 76
    Rick, can you post a pic?
    ej
    EJ Korecky
    check out my products on Facebook
    https://www.facebook.com/profile.php?id=100075564523814
    Destin FL
    Liked: 647
    Quote Originally Posted by ejsprint30 View Post
    ej
    Eric;
    Superior quality in workmanship, REASONABLE, QUICK, and very pleasant to deal with.
    Call him to discuss why to plumb there. A wealth of knowledge, he is.
    V/r
    Iverson
    Ohio
    Liked: 76
    Thank you...very nice work
    ej
    EJ Korecky
