    Wheaton, Illinois
    Default Where is water drain for winter prep?
    I am unsure whether I will attend the scca event at Blackhawk in a few weeks. Regardless, this will be my first winter in the car and I need to drain out the water. I tried to pull it out via the radiator cap area, but as you all probably know you can't get a tube down far enough to do the job.
    So, where do you drain the water for the coolant system?
    Thank you in advance.
    Maybe disconnect bottom hoses on rads...
    Wheaton, Illinois
    Will this get all the water out of the engine? I really don’t want to crack the motor….I worry just opening the radiator lower hose will only drain the radiator and not the internal channels of the motor?
    Late Braking Member
    Danville, California
    Liked: 217
    One of my kids did a 4th grade science fair experiment showing how freezing water would break things. If I remember correctly, with about 15% airspace available in a sealed container it wouldn't break because air compresses easier than water...
    So, if the block and cooling system are near empty it shouldn't break even if it freezes.
    But then you and I are trusting an 10 year olds science fair experiment.
    Quote Originally Posted by janton9736 View Post
    Wheaton, Illinois
    love that! I’ll plan I’m filling it up with coolant for the winter like my sedan race car. I was just hoping to make it less messy with a real drain.
    Lafayette INdiana
    Liked: 295
    I keep antifreeze in mine.
    Pittsboro IN
    Liked: 281
    Pull the lower hose off the radiator to drain then add anti-freeze for storage
