Results 1 to 17 of 17
    Mississauga, Ontario
    Liked: 902
    Default Replacing sheet metal screws on the tralier
    All,
    Well, the Haulmark trailer is becoming about as *vintage* as I am - its seen almost 25 years of racing use, and I am finding a number of long delayed maintenance jobs are in my future.
    One of the ugly jobs is to methodically remove and replace all of the #10 self drilling screws that were used to mount the ally sheet walls to the frame of the trailer - after all these years they have rusted badly and are beginning to stain the aluminum. They are barely 5/8" long when you include the drilling tip in the length.
    My thought is to use the exact same, pan headed fastener except in stainless. Surely there are other, better ideas amongst the group (or I thought I would at least ask before installing literally 1,000 of these!)?
    cheers,
    BT
    Orlando Florida 32812
    Liked: 605
    stainless for sure.
    as to being #10 (grip width/diameter/whatever it's called) old rusty screws were - maybe try a tiny tiny bit wider in a metric for enhanced grip on both pieces of metal
    Liked: 3787
    One possible problem: If you remove a #10 old screw and insert a new #10 you may find that it doesn't tighten. You may have to use #8 to get proper grip. Or, possibly insert a dap of sealant/adhesive in each hole before inserting the new #10.
    Columbus, OH
    Liked: 69
    Have done this exercise twice (two different trailers)...
    Yes, stainless screws bought in bulk online (forgot who I used)
    Square drive head is much easier to use
    Pan head is not a bad idea if available in the correct drive.
    I used the same size as I took out, did have a couple strip. I suppose one number size larger is an option.
    Craig Butt
    Londonderry, New Hampshire
    Liked: 101
    Lots of places probably have them. These guys are racers and sell to a lot of trailer companies. It might be worth talking to them. I have no idea on the price https://www.engcomponents.com/fasteners
  10. #6
    Maineville
    Liked: 103
    Default Following
    BT,
    I need to complete the same exercise on my Haulmark trailer, please keep us posted on what path you head down and any best practices you learn from the process.
    Thank you,
    Joe
  11. #7
    Liked: 1487
    rivets
  13. #8
    Spokane, Washington
    Liked: 17
    My trailer used "double square", which it seems only trailer guys use.
    https://www.tacomascrew.com/Product/083-502-1
    https://a.co/d/gmwd18Q
  14. #9
    Derbyshire, United Kingdom
    Liked: 322
    Bill - stainless steel should not be used directly with aluminium as it will result in galvanic corrosion of the aluminum, especially on something like a trailer that will get wet:
    https://www.albanycountyfasteners.co...-and-aluminum/
    Either using a non-metallic washer or a corrosion inhibitor such as Duralac will help to minimise later problems.
  16. #10
    Destin FL
    Liked: 645
    rivets
    Yep
  17. #11
    Liked: 1487
    After spending a month replacing all the fasteners and sealants under my RV's top edge seal/gutters, I can confirm that SS in contact with AL will make a mess.
    They used self-drilling screws, and everywhere a screw went through the gutter the powdercoat just de-laminated.
    I did replace them with more stainless (because rust is just as bad) but I dipped each screw in paint as I put it in (we used to do this to rivets on missiles).
  19. #12
    Liked: 902
    Didn't think of that - thank you!
    bt
  21. #13
    Liked: 322
    Happy to help, Bill...we limeys have our uses
    Link below for Duralac, if needed:
    https://www.silmid.com/us/sealants/j...various-sizes/
  23. #14
    Prescott, AZ
    Liked: 182
    Zinc chromate if you’re an old aircraft guy.
  25. #15
    Louisville, KY
    Screws don't work that way. Wire and nails yes, but screws go the other way. A #8 screw is smaller than a #10.
  27. #16
    Liked: 605
    Learn something every day......that's part of why ApexSpeed is great.........SS vs. Alum. I have not much experience in such work but at first thought the SS sounded good.
    I forget if my bolts were SS or Alum but.........
    When I installed large bolts through the side of the alum box trailer for the tire rack install, I at least isolated them from the outside surface with thick rubber gromets under the heads for waterproofing before putting sealer over and around the heads. All has been well for about 8+ years since.
    Now I need to break out the magnet tool to check, SS?
  29. #17
    Liked: 947
    It depends on the grade of stainless. Most fasteners for marine use are 300 series and non magnetic, or if work hardened, very slightly magnetic.
