Originally Posted by
Dstarbuck
Looks just like my Lola wheel hubs, but your diagram doesn't show the rest of the locking mechanism (at least if it is like mine). There should be a large spring that keeps the "piston" (29) seated against the circlip which goes on the hub after the spring, bearings, and piaton are inserted. The 1/4" ball bearings go into the hub from the inside.
The groove in 29 let's the ball bearings fall into it when 29 is depressed by the proper wheel nut socket, then letting the wheel nut spin off. If 29 isn't depressed, the wheel nut will not get past the ball bearings.
Not sure why it's not letting me post pictures on this thread, but if you go into my t94 build In the BOSS section, I have a picture of the hub disassembled as well as the parts breakdown.
