Results 1 to 6 of 6
    Watkins Glen, NY
    Default Sold. Reynard. 88 SF FC
    Sorry to see it go . . . but IT IS SOLD!
    Our 1988 Reynard SF – Formula 2000 (Continental) in current racing trim, with a “garage full” of spares.
    A long, colorful, and successful history, including SCCA racing in the Northeast; a dominant contender in the “formula cars only” Race Car Club of America; and the Formula Pro Racing Series, including oval tracks; and consistant taker of Fastest Time of Day (FTD) in SCCA solo events.
    Recently “freshened” by a racer who has worked on these cars since they were new!
    NUTS and BOLTS? Please read on . . .
    > Frame is absolutely straight and true, with no breaks or bends.
    > Chassis is very stiff: the floor pan is rivited and bonded.
    > Front bulkhead is cast aluminum (just as it came from the Reynard factory.)
    > Aligns perfectly, and corner weights can be adjusted to within ± 2 pounds!
    > All heim joints, rod ends are like new, along with rocker arm bearings, bushings, etc.
    > Motor is a strong Marcovicci & Wenz build, with a Quicksilver head.
    > Petronix Ignition coupled with a AutoMeter selectable rev limiter.
    > Transaxle is the signature Reynard magnesium alloy casting, using standard Hewland
    Mark 9 ratios.
    > Clutch consists of brand new pressure plate and like-new Tilton clutch disk.
    > Suspension features HyperCo springs mated to Penske double-adjustables.
    > Front suspension is droop-limited.
    > Cooling system upgraded with light weight, enhanced flow radiators.
    > Robust braking system featuring LD 20 calipers front and rear, aeroquip stainless brake lines.
    > Aerodynamics package includes Averill Ultra front wings, Van Diemen rear wing, difusser,
    plus original Reynard front and rear wings, plus others.
    > Fuel cell and lines in excellent condition.
    > Brand new battery.
    > Equipped with a real, hard-wired transponder - NO subscription.
    > Cockpit is suprisingly roomy, and will accommodate a larger driver. Everything is
    adjustable.
    > Right “at hand” while strapped into the cockpit are Brake Bias Adjuster and rear Sway Bar
    Stiffness selector.
    > Fire supression system fully charged.
    > A single-race set of the current spec Hoosier bias 7x13’s and 8x13’s - R-60 compound. Also
    older Hoosiers.
    > Package includes 2 full sets of Dymag MAGNESIUM racing wheels - super strong, super
    light! These DO NOT FLEX in the turns!
    SPARES? Please read on . . .
    In addition to the car in full racing trim, package includes like-new, and original equipment spares in every category, including
    > Aerodynamics
    * A pair of original Reynard front wings - like NEW condition
    * A pair of used original Reynard front wings
    * A variety of short cord and long cord front wing end plates
    * Chrome-moly front wing through tube - brand NEW
    * Rear wing main element - high downforce - 36” length x 10” cord, with end caps
    * Original Reynard rear wing - small dent in leading edge
    * Rear wing rectangular end plates - fiberglas over aluminum mesh
    * Rear wing horizontal stabilizer tube, with end brackets
    ** It may not be readily apparent, but with this combination of “wings and things",
    one may fine-tune downforce front-to-rear, and for side winds. **
    > Body Parts
    * Nose – fiberglas, original Reynard - nice condition
    * Side Pods – fiberglas - brand NEW
    * (3) extra mirrors
    > Brakes
    * Girling master cylinder
    * Master cylinder extra reservoir - also for slave cylinders
    * 9 7/8” slotted rotor - brand NEW
    * Full set of Ferodo large racing brake pads - brand NEW
    > Chassis
    * (2) Nose / front wing locator tubular braces - one is “long reach”, and the other is “short reach”
    * Radiators – both original Reynard - excellent condition
    > Hardware
    * Rod ends - about 20 miscelaneous sizes and thread lengths
    * Socket head cap screws – a few plastic bags
    > Motor
    * (2) 2-litre cams – used but fine condition
    * Cam followers, matched to the GT 1 cam above
    * Various drive belts for cam timing, oil pump, etc.
    * Spark plug and coil wiring harness
    * 2.0 litre starter – used but functional
    * Full set of high-rate valve springs from Jay Ivy
    * Spare 2.0 litre valves - need grinding and conditioning
    * Water pump - like NEW
    > Suspension Parts
    *** Custom built front and rear suspension alignment bars ***
    * Upright - brand NEW
    * Rear A-Arm – believed to be left side
    * Lower A-Arm 18” x 16” with 9” hypotenuse
    * CV Joint spacers – aluminum – used to extend half-shafts
    * Spare Heim joints for everything! Wishbones, rocker arms, toe links, front stabilizer
    drop links, rear stabilizer links
    * Rear toe link bar
    * Spherical bearings for front rocker arms
    * Springs - 5”, 6”, and 7” springs ranging from 350 lbs/inch to 800 lbs/inch
    * U-shaped suspension pickup – bolts to transaxle
    * V-shaped suspension pickup – bolts to transaxle - anti-dive, anti-squat
    * (3) Lightly used wheel bearings
    > Transaxle
    * Brand NEW Tilton F3 clutch disk
    * Various used clutch parts
    * Spherical bearings for transaxle
    *** New owner may select a couple of additional ratios from a wide variety of Hewland
    gears ***
    >Wheels
    As mentioned, the Reynard comes with a complete SECOND set of Dymag magnesium racing wheels. A third complete set of Dymags may still be available at an additional cost.
    ** Unless listed as “new”, all spares are used, very well cared-for, and fully functional. **
    DOCUMENTATION? Reference volumes, including
    > Reynard Shop Manuals with exploded views of components
    > Reynard suggested and updated Set-Up specs
    > Hewland recommendations for Gearing at any Track
    In short, this car is not only reliably fast, but also easy to set up, easy to drive, and easy to maintain. The spares package is obviously huge. 100% RACE READY, with no surprises! Asking $11,500
    Kindly make initial contact with Ed Lo Presti using private message here on Apex Speed Forum. . All inquiries answered.
    Chicago, Illinois
    Liked: 9
    Any pics of the car and spares?
    Watkins Glen, NY
    Default Sorry for photo trouble
    Sorry, Folks, for the up-side-down images. I am attempting to figure out how to REMOVE them, before re-posting them in up-right position.
    By the way . . . fortunately, this car was never ACTUALLY up-side-down!
    Patience . . .
    Ed
    And Jimmy,
    Once I collect all those spares into a group setting, I'll try to get a wide-angle photo.
    Every one of those spares is either NEW , like new, or used-but-in-great-condition. (Several are in their original boxes!) Anything that was worn or suspicious was discarded. If you want a photo of anything in particular, please let me know via Private Message, and include a phone number where I may contact you.
    Thank you for your interest.
    Watkins Glen, NY
    Default Thank You!
    Many , many thanks - - -
    First of all, to Dan Pyanowski, for his wonderful job of "going through" everything, and re-freshening a striking 35-year-old beauty.
    Secondly, for all you gentlemen who expressed an interest, and kept me on the telephone.
    And to this Apex Speed Forum, where Great Minds meet . . . and buy things.
    I am very pleased to say our (former) Reynard is headed for The Great Lakes Challenge Series !
    And now I am left with "the other half of the garage" still full of EQUIPMENT, like scales, and setup platforms, and chassis stands, and alignment gauges, and a quick jack, motor diagnostic and tuning items. Most of them are Longacre brand, and came from Pegasus - no junk ! So please watch the "Parts For Sale" part of the forum over the next few days - - everything must go !
    Watkins Glen, NY
    Default Race Shop Equipment
    For all those of you who have asked, here is the link to my ad on Open Classifieds:
    https://www.apexspeed.com/forums/sho...832#post642832
    Thank you again, for all the inquiries.
    Ed
    Lancaster, NY
    Dan Pyanowski is one of the best guys out there!
