Results 1 to 11 of 11
    NY
    Default Air shifter, tank vs compressor
    Fitting a air operated shifter to my car with a Quaife trans. It's a Miata, but I'm a former DSR owner, please don't hate! I figure there are some folks here that have tried both re-chargeable high pressure onboard tank or a small compressor and low pressure tank. What has worked best for you?
    Spokane, Washington
    Liked: 17
    I tried a small compressor from a motorcycle racing place. It died immediately. Now I use CO2, a little bottle lasts for 100's of shifts.
    third stone from the sun
    Liked: 101
    We use a Geartronics system with a compressor on a Swift 016 works great, it does add some ; weight , some people have problems with the compressor over heating and shutting off it needs good air flow, some folks add a small fan to cure the problem.
    NY
    Dee can I ask what brand the compressor is? I've heard of people having issues with cheaper pumps.
    Liked: 101
    Quote Originally Posted by BERG Racing View Post
    I will check make and model and get back to you
    Dee
    Liked: 101
    Quote Originally Posted by Dee View Post
    Dee
    compressor is marked Geartronics
    Liked: 101
    I will check make and model and get back to you<br>
    Dee
    <br>
    NY
    thanks
    Wetmore, CO
    Liked: 109
    Default Yup
    I have had both. Love using the carbon paintball bottle and recharging with scuba tanks but it just adds overhead. The compressor is much easier!
    near St. Louis, MO
    Default Air compressor vs tank
    The compressor/tank also is a pretty big drain on the electrical system when it kicks in.
    For those of you who've had both what is the approximate weight saving when going to a tank from a compressor?
    Mike M.
    NY
    follow up question to those that are using the high pressure/no compressor option. Are you monitoring the bottle pressure or recording it to your data system? Do you have a warning system for low pressure? What sensor are you using?
