Results 1 to 8 of 8
    Destin FL
    Liked: 645
    Default Spark Electrical Source
    Gents;
    I have a “FAST” dizzy on my engine. Any clue what that is?
    Paso Robles, CA
    Liked: 285
    Probably a trigger setup to work with some specific ignition system. Perhaps the engine builder can give you some clues or sell you the necessary parts to work with that.
    David Ferguson
    Veracity Racing Data
    Shift RPM App for iOS
    805-238-1699
    Fallen Friend
    Pensacola, Florida
    Liked: 168
    https://www.fuelairspark.com/
    Edelbrock/Comp Cam bought up several aftermarket companies.... probably what you have.
    NC
    Liked: 303
    Looks a bit like a Bosch VW distributor
    Destin FL
    Liked: 645
    Gents;
    FAST has the SP200 coil: 1.2 ohm and 41k+ volts. That’s my choice.
    near Athens, GA
    Liked: 830
    Gents;
    Just make CERTAIN that you do NOT try to match that COIL with a 'normal' electronic ignition module that's not designed for it. The module will only last about 30 seconds.... (ask me how I know?) - 3+ ohms or more for most of the early versions of 'electronic points'.
    Destin FL
    Liked: 645
    Steve;
    Thanks for the post. I did email Eric at QS, and this was his recommendation. Thx for the input.
    Santa Cruz, ca
    Liked: 183
    It's probably one of these conversions. https://www.summitracing.com/parts/fst-700-0001
    I have been running this system for years with great success after figuring out that pesky coil issue that others pointed out .
    legal in most series as it maintains the mechanical advance.
