1990 Citation Pinto FC. Tilton 7 1/4 clutch, Saab annular slave cylinder. Pressure plate just surface ground. New Tilton Disc. Verified stack height on flywheel was same as before new disc and surface grinding. Actually a bit taller since grinding onlt took about 0.005" off.
Replaced slave O Rings. Tested for leaks with bar bolted to bell housing and master hooked up. no leaks (bled it first). Stroke limit set by pushing car in gear while driver gradually moved clutch in until it JUST slipped. Set pedal stop 1/4" past that point. Pushing it around garage and keeping it in gear to keep from rolling worked as usual.
Went to do test drive around block today. Pushed it into driveway, slipped it into gear as driveway is a bit sloped. Installed driver, slipped it into neutral, started engine. Put clutch in and slipped into first and eased out of driveway. There is a dip at the bottom that I always coast over, so put clutch back in there. Pedal felt fine for an instant then went to floor. and all of a sudden no drive. Could shift from one gear to another, clutch pedal dropped right to floor.
Got it back into garage, and there was a big puddle of brake fluid on the diffuser, but it was all at the front, none anywhere near bell housing. Looked closer and found that line had gotten pinched and that was where the leak was from.
Removed bad line. Confirmed failure.
Tried blowing compressed air into slave cylinder via fitting that line connected to on bell housing and rubber tipped air nozzle. It appeared that no air was escaping.
Thought might had had a cv joint failure jacked rear wheels up and checked all 4 and they all still turn the halfshaft.
next thing to try tomorrow is to remove box rear cover and verify that the pinion shaft is connected to the rear wheels by trying to turn it with the wheels on the ground. with box in neutral Should not turn.
Then going to try same thing with layshaft with box in neutral also.
If all of these check out I am lost. I am suspicious that somehow the slave cylinder has "jammed" in the released position and that the car will have to be split. and that is a huge job. especially considering I just got it together. Failure of the clutch is also a remote possibility in my mind.
But this seems far fetched to me as there is a ton of spring force it would have to hold against for that to happen.
Anyone have any thoughts that might help?
Any help is greatly appreciated.
