Gents;
Rough guess, please?
Gents;
V/r
Iverson
745 Watts = 1hp
50A x 12 V = 600 Watts
With that rough math, less than 1hp.
I would expect it to be about equal if the gear ratio driving the pulley is the same.
There will also be a couple percent mechanical efficiency loss, no mater how it is driven (usually about 2% for a toothed belt), along with internal efficiency losses in the alternator itself, which can also easily be 20-45%, depending on the design.
https://www.delcoremy.com/documents/...ite-paper.aspx
Can you switch it off for a temporary power gain?
Will still take some HP to drive it even when off
Add and electric clutch in there...
...and have something else that can fail.
