Results 1 to 11 of 11
    Spokane, Washington
    Liked: 17
    Default Zink Z12 carb linkage
    I'm putting a 1600 single port in the 82 Zink I've been trying to sell. It seems the carb has be installed backwards to clear the roll bar brace. Before I do a bunch of fabrication, am I missing something?
    Tacoma, WA
    Liked: 323
    Probably not legal, but a Weber DFV is a mirror to the DGV
    -John Allen
    Tacoma, WA
    '82 Royale RP31M
    Burr Ridge, Illinois
    Liked: 301
    Quote Originally Posted by scorp997 View Post
    Just for clarification, I'm curious...what's "Probably not legal"?
    Glenn
    Spokane, Washington
    Liked: 17
    I'm just making it run, I don't care about legal. It just seems weird that the carb would face backwards.
    I'm using the Solex 28 that came with the car, if it's facing backwards, and the cable connects like stock, it has to pull towards the front of the car. The cable will have to go 360 degrees to be in the right place.
    I'm just wondering if there is supposed to be a bellcrank or something.
    alabama
    Liked: 148
    Lots of vees have 28 carb mounted backwards. It is supposed to prevent fuel from dumping into bowl
    I have been told it helps stop the bogging off corners and under braking.
    The linkage is a bit more involved.
    Tacoma, WA
    Liked: 323
    Quote Originally Posted by pacratt View Post
    Glenn
    I don’t believe the DFV is allowed in Formula Ford’s rules
    -John Allen
    Tacoma, WA
    '82 Royale RP31M
    Tacoma, WA
    Liked: 323
    Oops!!!! My mistake!! I thought this was a Zink 16 Formula Ford!! I guess I need more coffee!
    -John Allen
    Tacoma, WA
    '82 Royale RP31M
    Lakeside
    Liked: 58
    Default Carb
    For clarification, the carb in STOCK orientation with the bowl to the rear, the cable comes from the rear- many times through a fan shroud.
    If the carb is reversed with the bowl to the front, then a pulley system may have been used to pull the cable up the firewall and to the carb.
    Throttle shaft fittings can be reversed, moved from side to side, or modified to suite your application.
    Hope that helps
    Dietmar
    www.quixoteracing.com
    fvraceri@cox.net
    BLS
    Spokane, Washington
    Liked: 17
    Thanks for the replies. It's all done now.
    Liked: 301
    Quote Originally Posted by Onebadbug View Post
    Love to see what you built....picture(s)?
    Glenn
    Spokane, Washington
    Liked: 17
    NO!
    Nothing to be proud of.
    It was supposed to have been driving with this carb, but I had to make tabs for a return spring, clearance the no longer used choke area, make a bracket that bolted to the carb studs; so there would be something to attach the cable to. Made a new throttle stop adjuster.
