SOLD
PRICE CHANGE! $5,500 I need room in the garage.
A change in direction makes this Elden Mk8 Formula Ford roller available. The car is dissembled, the frame ready for paint and then reassembly can begin. Includes a race ready Hewland Mk9 transmission that was just gone through. All new rod ends are installed on the suspension pieces. The frame was updated to allow the use of a Hans device Note; in the pictures, the orange #6 is a sister car.
The car is available for $6,500.00 NOW $5,500
Contact information: mmreed28@comcast.net
Complete information is as follows:
1972 Elden Mk-8 AM73 13 (Last raced in 1989)
· Frame is stripped & ready for media blasting and painting
· Hewland Mk9 transmission. Transmission was gone through and refreshed by Archie Hodge of R&A Mfg. (Renton, WA) in Feb,
2022. Archie reported the 9.31 CWP looked new
· New belly pan (uninstalled)
· Frame and belly pan are drilled. Holes in pan haven’t been countersunk
· All suspension pieces, uprights, A-arms, pedal assembly, etc. have been media blasted and painted
· All suspension pieces have been fitted with new high quality QA1 rod ends
· Spindles, uprights and spline yoke shafts have been magnafluxed and are okay
· Custom-made, unused fuel cell from AeroTech Service
· Aluminum fuel cell cover
· Front and rear sway bars
Shift linkage
· Elden Mk8 radiator
· Oil cooler
· Steering wheel, shaft, universal joint and steering rack
· Swirl pot
· Oil filter mount
· Motor mounts
· A set of original Dunlop steel wheels
· Original Smith gauge’s
· Four calipers. May/may not be rebuidable
· Three master cylinders. May/may not be rebuidable
· Two new Mk-8 noses
· Two new lower body side panels
· Center cowl section
· Engine cover
· Original shocks. Will need to be rebuilt
· Original springs
· Two half shafts
· Original brake lines are present and usable but could also be used as a pattern
· Original seat, built for someone who is slender
· Original headrest
· A new oil tank should be fabricated or replaced with a rear mounted tank. I have the old oil tank for a pattern
· A radiator shroud or mounting struts will need to be made
· Previous owner says he knows he has the log book but candidly hasn’t had to the time to do the search
· Miscellaneous bits and pieces
· New belts and fires system will be needed
Items such as wheel bearings, hoses, and other small items will need to be acquired
A complete set of deconstruction pictures on a flash drive is available
