I thought it might be a good idea to document these sizes for posterity if I can figure them out.
I have two cylinders - the std VD unit and one made by Tab McBlaine a looooong time ago (nice piece!). Tab had the part numbers for two of the three sizes, but not the 3rd. I've been trying to figure that out, so if someone has info it would be greatly appreciated.
There are 6 o-rings in the re-build kit.
Two thin ones go between the cylinder and the bore in the bell. Those are 2-032 size.
There's one that goes on the outside of the middle barrel - that's a 2-222
From what I've heard, VD got some dimensions wrong with either the glands on the outer and middle barrel or the dia of the inner barrel. There are three rings that go around the outside of the inner barrel. One is at the back of the outer barrel, and the other two are on the inside of the middle barrel. Evidently the Taylor kit has custom sizes to solve this. Tab tried to make his parts so this wouldn't be necessary, and he kept the inner barrel the same. The problem is that I only had one set of Tab's parts and of course trying to measure them after they'e been installed for years is a lesson in futility. I'm guessing that Tab was building parts that would use the original VD kits but not leak.
So I've been looking at Tab's drawings, and trying to determine o-ring sizes from groove sizes using the parker catalog, and I really can't figure it out, I can only get close. Measuring the rings out of the two kits I have using the parker cone gauge is pretty inconclusive. So maybe those are custom parts.
Gland sizes are 1.590 dia x .157 wide, the inner barrel is 1.414. I've narrowed it down to a potential of 5 sizes: 2-126, 2-127, 2-219, 4x32 or 5x30. Anybody know what the size actually is?
