All,
I am interested in understanding the mistakes we've collectively made when building a shop for our racing hobby/business. Let me save you the trouble of citing the obvious one: don't build it too small (can they ever be large enough?)!
We are beginning to plan out the next chapter in our lives, and we will end up on the NE coast of Canada with more than enough acreage (somewhere between 6-12 acres is in our snack bracket where we are looking). We will be "slightly" in the country, about 20 minutes form a thriving metropolis of some 40,000 people. As such, we will be on well-water, septic, and propane.
Here's what I am thinking about:
- 3,000 sq feet of shop space, well separated from the house
- Concrete slab
- Possibly indoor room for the trailer, but am also considering a carport off the side of the building
- Hot water on its own heater, 2 piece bath
- 220 (lathe, TIG)
- A single 2 post lift well off to the side of the shop
- What I would call a 1.5 story construction with a single plane canted roof, with a loft running down the length of the building
- Heat pump system (quite popular in the region, and this is an April-October residence for us)
- Epoxy floor coating
- LED lighting, if only for the need to almost never change a bulb/fixture
- Built-in sound system. Place needs to rock
- Am thinking seriously about a solar field install, as we have ample room for it and the region has a robust FIT program
The house will be a single-story mid-century modern design, so the shop can't really be a metal/pre-fab style: there will be a need to have it "fit in".
Yeah, there's a lot of work to do yet! I would appreciate your thoughts on what NOT to do, and of course, what should I be thinking about that I have yet to consider.
Thanks in advance,
BT
