Results 1 to 6 of 6
  2. The following 4 users liked this post:
    Senior Member kea's Avatar
    madison heights,mi
    Liked: 601
    Default Battery info
    I have a 12V trouble light that I use to do as they suggested. And a 10amp battery charger that is voltage limited (got it in the Pulsar battery days) Doing it that way for decades and recovered more then a few batteries, thought to be gone.
    Averill Racing Stuff, Inc.
    www.racing-stuff.com
    248-585-9139
    Liked: 1261
    I was using a 2amp charger at the track and it was always so slow.
    Called Odyssey to see what the max amps the 680 could take on a charge. They said 20!
    So I bought one of these:
    https://www.amazon.com/Battery-Tende.../dp/B089GZV2PR
    Mainly use the 8amp rate but I'm now thinking I should be using the 15.
    Senior Member Pi_guy's Avatar
    New York
    Liked: 229
    Interesting battery recovery process.
    My stand is it is cheaper to replace batteries every year than have issues.
    Liked: 1261
    Quote Originally Posted by Pi_guy View Post
    A lot of things 'appear' as battery issues. (such as mine early this year - fuel pump)
    Your method allows ruling out the battery quickly.
  9. #6
    New York
    Liked: 229
    First thing I check is the battery always. But the first item I check with data analysis is battery avg and high and low values if they are not in spec data is possibly not accurate or just noise.
