Results 1 to 10 of 10
    Mississauga, Ontario
    Liked: 900
    Default Broken Helmet..........................
    All,
    Mostly just a public service announcement here......
    As you may know, I had a pretty big shunt at the start of the season at Mosport. The car damage was extensive, and the Hans device came into play. It wasn't a direct head-on hit, more of a slight angle but an almost instantaneous stop. I pulled the helmet (Arai, GP3 I think, only 2 seasons old) out of the bag a while back to clean it up for next year (!) and noticed multiple hairline cracks emanating from the mounting points for both the Hans mounts. Once again, a possible future disaster saved by my rather anal-retentive tendencies toward race car/equipment cleanliness..... So, check your helmet carefully after any incident....
    Which got me looking at the Hans device. Its gotta be 15 years old minimum, and there have been a few pretty big impacts over the years. I am going to replace it as well, but am totally confused as to "what" model to consider. Back in the day, there were only 2 versions I think: sit-up or laydown.
    Curious as to what formula car drivers are using, or avoiding. FWIW, its an RF 91.
    cheers,
    BT
    Liked: 1261
    NexGen...
    I believe you need to get them recertified every 5 years.
    They replaced all the 'strapping' and checked it over.
    South Carolina
    Liked: 673
    My original looks built to withstand much more than the straps could ever deliver, so I am not sure you need to replace the HANS. The straps can / must be replaced. I am paranoid by trade, but not sure I'd put the money there. You might ask the people at HANS?
    Swift DB-1
  7. #4
    Liked: 1113
    I agree. I can't see the HANS structure having the same stress as the contact points on the helmet shell.
    That said, I love my Neckgen, which gives me a lot more flexibility in seating position.
  9. #5
    Liked: 945
    All,
    cheers,
    BT
    Good catch. Fiberglass & resin may develop stress cracks when heavily loaded, but as you found, not right away. It can be sped up with gentle heat (hair dryer) to reveal the cracks sooner.
  11. #6
    Orlando Florida 32812
    Liked: 601
    Send it back to HANS for their inspection and possible recertification....they can replace the straps....and maybe the strap accessory pieces too
  13. #7
    Liked: 900
    Default Thx guys
    Never thought of recertification.
    cheers,
    BT
  14. #8
    near Athens, GA
    Liked: 830
    BTW... the GCR does NOT require recert for a HANS .. under any specified circumstances. And no mention is made of the tether either.. However, I was looking at MY tether and I think it's about due.
    The GCR does, however, say that "any crash damaged HELMET" should be returned to the mfr for inspection after any crash.. "should", but not "REQUIRED" or "MUST".
    I just happened to be looking at that section yesterday...
  15. #9
    Hudson, Ohio
    Liked: 208
    For what it's worth...SVRA requires re-certification on HANS devices. I believe it is every five years. I got stopped during tech a couple years ago and had to borrow a friend's device in order to race.
    Ralph Z
    1968 Alexis Mk14 Formula Ford
  16. #10
    Ottawa,ON
    Liked: 138
    I'm not sure about SVRA rule but my HANS is the older adjustable with SFI sticker so it needs recert every 5 years.
    But apparently the FIA stickered ones do not require it.
