Results 1 to 5 of 5
Thread: Con rod bolts
    cambridge, massachusetts
    Default Con rod bolts
    Where can you get aftermarket connecting rod bolts for a gsx r600? Can't find them on the ARP website.
    Will
    covington ga
    Liked: 72
    Quote Originally Posted by Vulnavia View Post
    Will
    Unless you just want to spend the money, I've never used aftermarket connecting rod bolts. The people to contact if you want them would be Sparky Grape, Richard at Rilltech, or Greg moon.
    Then you use new bolts from Suzuki?
    Will
    San Jose
    Liked: 83
    Default What does
    What does the manual say about replacing bolts after opening the rods? For a stock engine I would recommend going with the manufacturer recommendations. For a Kawasaki the bolts are single use, release the tension and replace the bolts, install using bolt stretch according to the manual.
    covington ga
    Liked: 72
    Will
    I reuse the bolts.
