Results 1 to 12 of 12
    Buffalo, NY
    Liked: 6
    Default Spark Plug Wires
    I'm looking for a set with decent cables and 90 degree ends for the spark plugs, which will fit better under my head cooling ducts. Local auto parts guys can't seem to locate anything, even a universal set that I can assemble. Any recommendations?
    Spokane, Washington
    Liked: 17
    Buffalo, NY
    Liked: 6
    Appreciate the link. Looks like those are preassembled with a straight boot on the plug end. Wish there was more info, or a Pertronix item # to verify what they are. Those 4 digit #s don't translate.
    alabama
    Liked: 148
    Chris Cox at Noble engine makes up sets as need for each cooling application
    Most of his sets are straight at coil to 90 degree at heads.
    Los Angeles, CA
    Liked: 290
    Provide a picture of the cooling duct near the plugs.
    Buffalo, NY
    Liked: 6
    Quote Originally Posted by veeten View Post
    Thanks for the tip, Sherman. I'll keep it in mind.
    Torrington CT
    Liked: 480
    https://www.holley.com/products/igni.../parts/3009ACC
    V8 set - if you are good you can make 2 sets.
    Available at Advanced Auto, O'Reilly, etc.
    ChrisZ
    Buffalo, NY
    Liked: 6
    FWIW, you can see that these have been relieved to fit the larger straight boots. I plan to repair them and use 90 degree boots.
ID:	99803   Click image for larger version.
    Buffalo, NY
    Liked: 6
    ChrisZ
    Those might be okay. On the subject of quality, from what I've seen most of the wires have a resistance of 350-500 ohms/foot. For a Vee, would it be worth getting these Taylor wires with a claimed resistance of just 40 ohms/foot?
    https://www.summitracing.com/parts/tay-83637#overview
    Florance, AZ
    Liked: 32
    Default Beldon
    Quote Originally Posted by sagero View Post
    I use old school Beldon solid core copper tinned spark plug wires wires, these connectors should fit:
    Spark Plug Boot BEL 727501 | Buy Online - NAPA Auto Parts (napaonline.com)
    Spark Plug Wire Terminal - Snap Lock BEL 727006 | Buy Online - NAPA Auto Parts (napaonline.com)
    John H.
    Reynard 88SF
    Buffalo, NY
    Liked: 6
    Quote Originally Posted by azjc View Post
    That looks like a good option. I should be able to get some bulk wire from NAPA
    Thanks everyone for the info!
    Senior Member mmi16's Avatar
    Liked: 307
    Wasn't the Nology coil and grounded spark plug wires the 'hot ticket' in FV a few years ago?
