    Albany, NY
    Liked: 235
    Default Virgin Brake & Clutch System
    My FF has new brake & clutch lines, new master cylinders. It's all dry. Is there any first time technique to follow or should I just use the typical bleeding method as usual? Should I raise the front end, open the bleeders, and let the fluid gravity flow for a while?
    Thanks for the advice.
    Orlando Florida 32812
    Liked: 597
    bleed it
    use it
    re-bleed it
    use it
    re-re-bleed it
    use it
    Pittsboro IN
    Liked: 278
    Bleed it as normal with the possible exception that you MAY need to do the master separately
    new zealand
    Liked: 110
    The secret is to get the master cylinders 'working' (meaning very little air and able to pump fluid downstream). Fill the reservoir and crack the union/banjo at the outlet of the MC; after maybe 15 seconds there should be fluid dribbling out of the union; if not undo the bolt another turn and wiggle the banjo. Then bleed just the MC by having the union bolt open when the pedal goes down, tighten it before it comes up. Often just 3-4 such pumps are required.
    Then bleed the rest; I tend to leave the caliper bleeder closed, I pump the MC several times to build pressure (there will be a lot of air in the line), then crack the bleed (and let a good 5 sesonds go by before tightening it; it lets the residual air pressure out; takes a bit).
