Thread: Steering Effort
    Ridgecrest CA
    Default Steering Effort
    Bringing an old BM formula car back from mothballs and I'm finding the steering effort dead and hard to the point of having difficulty in tight maneuvers. 8 & 10 inch wheels, 8x20 and 10x22 tires. Currently over-pressuring the front but looking into better options:
    Increase negative camber?
    Switch to 7x20 fronts? (& 9x22 rears)
    Who's done what and how did it work out?
    Unfortunately it has a tiny steering wheel, but that's all that will fit in the tub. Jacked up, steering feels free and proper. And it's only an issue at slow tight sections found on small sites.
    Saint Louis, MO
    Liked: 310
    1. Slower steering rack. But that is not very helpful on small, tight courses due to the increased steering input.
    2. Longer steering arms. Same as above.
    3. Go to the gym and build the necessary muscles.
    Senior Member Farrout48's Avatar
    Florida
    Liked: 134
    Measure Caster. When I got my WF1 it was set at 12 degrees. Hard to turn at low speed and had to fight steering wheel from wanting to return to going straight in a high speed turn. Reduced caster to 6 degrees and problems went away.
    Craig Farr
    Stohr WF1 P2
  4. The following 3 users liked this post:
