Results 1 to 5 of 5
Thread: Clutch Question
    Senior Member Rondo's Avatar
    Delaware
    Liked: 22
    Default Clutch Question
    In the spirit that no question is a dumb question.............non -tapered side to the flywheel, tapered side to the pressure plate...correct?
    Liked: 1261
    Yes.
    I think if you reverse it the tapered side of the 'hub' will contact the flywheel before the disc surface.
    Prescott, AZ
    Liked: 182
    Yes.
    That’s the way I cross check. Hand hold the parts together.
    Member scotty82's Avatar
    Denton, Texas
    Liked: 63
    Flat side to the flywheel for flywheel bolt clearance if need be .
    Cone side facing the gear box .
    Scott Young
    Scott Young Enterprises
    scotty@sy-gearboxes.com
    West Union, IL USA
    Liked: 319
    Default "Tightening these clutch cover bolts just don't feel right."
    One is perhaps likely to make this mistake just one time; although in my case that remains to be seen.
    (It is a $100.00 mistake...)
