Results 1 to 11 of 11
Thread: Shims
    Destin FL
    Liked: 645
    Default Shims
    Gents;
    Looking to source some donut shims:
    • OD: 2.375”
    • Thickness: 0.005”
    • ID: 2.125”
    • Material: Any, but aluminum is ideal for not having to deal with dissimilar metals.
    Any help?
    Liked: 1871
    Have you looked in McMaster Carr?
    Destin FL
    Liked: 645
    RP;
    I did, but my search skills are wanting.
    Derbyshire, United Kingdom
    Liked: 313
    In the UK, but worth considering:
    https://www.ebay.com/itm/224326415431
    Alternatively have them laser-cut?
    Red Neck Riveria, FWB, FL
    Liked: 105
    Default Beer Can?
    Aww.. its only 0.004 inches - sorry.
    Cheers - JIm
    Paso Robles, CA
    Liked: 285
    Here is what you can find on McMaster-Carr. The standard sizes are 2" ID, 2.75" OD, so you would need to trim, but it's only 0.005 thick, so should be pretty easy:
    https://www.mcmaster.com/shim-washer...ickness~0-005/
    Of course, you could just cut your own from aluminum shim stock (6"x50" roll is $26):
    https://www.mcmaster.com/shim-stock/...rial~aluminum/
    Or you can have them make you a set of 4 for $56:
    https://www.mcmaster.com/shim-stock/...order-shims-5/
    David Ferguson
    Veracity Racing Data
    Shift RPM App for iOS
    805-238-1699
    Destin FL
    Liked: 645
    David;
    In my search, I immediately went to McMaster-Carr. Since these hub bearings are a standard size, I thought there might be a source that has compatible shims.
    But I am grateful for the guidance.
    Incidentally, I call Monday to place my order to finish my button plate.
    Liked: 1871
    Rick:
    If you cannot find what you need or get someone to make them for you, I can. Won't be cheap, though!
    Destin FL
    Liked: 645
    Rick:
    RP;
    I’ll get a bearing and retainer off to you tomorrow so we can get it right. Half dozen should do it.
    Liked: 1871
    It looks like I can do you .002's, which you can double up - I'm out of .004 stock. Be a few days before I can do them.
    Destin FL
    Liked: 645
    RP;
    I shipped the parts this AM. Should be there by Wednesday.
