Gents;
Looking to source some donut shims:
- OD: 2.375”
- Thickness: 0.005”
- ID: 2.125”
- Material: Any, but aluminum is ideal for not having to deal with dissimilar metals.
Any help?
Gents;
- OD: 2.375”
- Thickness: 0.005”
- ID: 2.125”
Any help?
V/r
Iverson
Have you looked in McMaster Carr?
RP;
I did, but my search skills are wanting.
V/r
Iverson
In the UK, but worth considering:
https://www.ebay.com/itm/224326415431
Alternatively have them laser-cut?
Aww.. its only 0.004 inches - sorry.
Cheers - JIm
Here is what you can find on McMaster-Carr. The standard sizes are 2" ID, 2.75" OD, so you would need to trim, but it's only 0.005 thick, so should be pretty easy:
https://www.mcmaster.com/shim-washer...ickness~0-005/
Of course, you could just cut your own from aluminum shim stock (6"x50" roll is $26):
https://www.mcmaster.com/shim-stock/...rial~aluminum/
Or you can have them make you a set of 4 for $56:
https://www.mcmaster.com/shim-stock/...order-shims-5/
David;
In my search, I immediately went to McMaster-Carr. Since these hub bearings are a standard size, I thought there might be a source that has compatible shims.
But I am grateful for the guidance.
Incidentally, I call Monday to place my order to finish my button plate.
V/r
Iverson
Rick:
If you cannot find what you need or get someone to make them for you, I can. Won't be cheap, though!
It looks like I can do you .002's, which you can double up - I'm out of .004 stock. Be a few days before I can do them.
RP;
I shipped the parts this AM. Should be there by Wednesday.
V/r
Iverson
