Results 1 to 9 of 9
    South Carolina
    Liked: 673
    Default Bolt choice for rocker pivots
    My Swift DB-1 uses Allen head, coarse thread, black-oxide coated bolts in the rockers at the center pivot point. I use AN everywhere else, but Allen heads are unavailable in AN, as far as I can tell. So, I am wondering what other people use, and where they get them, since I went and stressed my current bolts beyond my comfort level for re-use.
    Swift DB-1
    Senior Member Raleigh's Avatar
    Sydney, Australia
    Default Ms / nas
    plenty of Internal wrenching / Allen head Fasteners used in Aviation. They are listed under NAS and MS part numbers but you may have to search for a coarse thread. Various Atlantic’s with Ground effect and high spring rates use AN-5 In the same location you describe. Your designers application of an coarse thread points to a relatively low load on these fasteners? What size bolts are they?
    refer to page 95 of link below
    https://www.skybolt.com/wp-content/u...-12-7-2017.pdf
    michigan
    Liked: 39
    Default Swift Rocker Bolts
    The original Swift DB-1 rocker bolts (front) are AN6-07A, rears are AN-6-11 and are fine thread. Yes, fine threads into an aluminum pivot shaft.
    Someone has changed (improved?) the design. You may be better off to replace the aluminum rocker pivot shafts (back to fine threads) and return to the original AN bolts to take advantage of grip length and bolt strength. Those aluminum pivot shafts are a simple lathe project.
    Finding authentic course thread bolts with the correct grip length will be a challenge. ARP may have something, but finding bolts from any other source, other than aircraft, will likely be from somewhere overseas and not worth the risk.
    Good luck with this!
  6. The following 3 users liked this post:
  7. #4
    South Carolina
    Liked: 673
    Okay, had a senior moment, and "mis-remembered" the thread pitch. They are 3/8-24 [fine thread] with a grip of 0.37 and total length minus head of 1.25"
    My car has allen heads in all the rocker pivots, front and rear. I am not aware of an AN spec Allen heads, but will look under NAS and milspec and see what I can find. If not, it's not a problem for the rears at least, and that is where I did the damage, so I can get AN to work. Many thanks for the help.
    Swift DB-1
    Royal Oak, MI
    Liked: 270
    Those match mine, then (SE1-based chassis)... though it doesn't look like at least Aircraft Spruce has them up to 3/8"...
    Vaughan Scott
    #77 ITB/HP Porsche 924
    #25 Hidari Firefly P2
    http://www.vaughanscott.com
    South Carolina
    Liked: 673
    Default Monroe-aerospace has this, but not in stock, and at unknown
    unknown price
    nventory 0
    Inventory Note Need additional stock? Call (866) 889-8212 or email
    Thread Size 3/8-24
    Grip 0.375 in
    Features Internal Wrenching
    Grip Tolerance ±0.010 in
    Head Type Key Locking
    Total Length 1.062 in
    Suggested Nuts for the Bolts 42FLW47FLWNAS1804NAS1805
    Industry Standards/Certification MS20006
    Weight .005 lb
    Minimum Order Note Minimum order is 1. Must order in increments of 1.
    Estimated Ship Date Ships within 10-14 days
    Swift DB-1
    Liked: 1475
    I have several of those style bolts. You will need a radiused washer under the head. They are serious bolts...
    Royal Oak, MI
    Liked: 270
    Preferred also the specific allen-head type spring lock washer, which I was able to find at McMaster-Carr. Assuming this is the correct parts list?
    Vaughan Scott
